Jabber Click2Call
ajaiyapandey
Have very basic question -
1. Where I can find the the Jabber SDK  ?
2. How to integrate Jabber SDK with Eclipse/ STS ?
3. How I see /change the Jabber Presence and notify to some third party for it's Status Change ?
Ajaiya K Pandey
dstaudt
1) The Jabber SDK tech center is here:
https://developer.cisco.com/site/jabber-websdk/overview/ with the SDK and add-on/extension downloads here:
https://developer.cisco.com/site/jabber-websdk/develop-and-test/voice-and-video/downloads-and-docs/
2) The Jabber voice/video SDK is a JavaScript library intended for use in PC browser-based applications.  If you are looking for Java-specific way to integrate with Jabber IM & Presence, you will likely need to investigate a 3rd party XMPP stack/library.  A listing can be found here: https://xmpp.org/software/libraries.html though note that Cisco does not directly recommend/support any particular XMPP library.
3) This walk-through has some details on basic IM & P event plumbing which should get you started:
https://developer.cisco.com/site/jabber-websdk/learn/im-and-presence-how-to/use-jabber-im-core-apis/
