Jabber guest - change video resolution or codec | Android SDK
Astaroth_666
is it possible to change the video resolution or codec using android sdk ?
background: for some devices with low cpu power the framerate is quite too low.
Cheers
Patrick
bw-systems.net
I am having exactly the same problem. My device has very low power concerning GPU and CPU. The problem is, I do not get access to the camera object from the SDK in order to limit resolution, bitrate etc. pp.
So I hope cisco will offer a solution for this problem in the next release, because this is a great bug in my opinion.
Did you found a different solution for now?
