Jabber guest SDK for android apps crashing
ahlam ali
Hi I'm trying to use CallSample app from jabber android SDK version 11.1.2
my jabber guest server version is 11.1.2.11
my android sdk version: 31
app modal: nexus 5 API 30
build:gradle version:7.3.1
I made sure to include the Guest SDK into the app
but when I run the app, the app crashes and I'm getting this results in logs.
2022-11-21 13:00:04.414 10029-10029/com.jabberguest.sample.call E/AndroidRuntime: FATAL EXCEPTION: main
    Process: com.jabberguest.sample.call, PID: 10029
    java.lang.UnsatisfiedLinkError: dlopen failed: library "libgnustl_shared.so" not found
        at java.lang.Runtime.loadLibrary0(Runtime.java:1087)
        at java.lang.Runtime.loadLibrary0(Runtime.java:1008)
        at java.lang.System.loadLibrary(System.java:1664)
        at com.cisco.jabber.guest.sdk.jcf.JcfJabberGuestCall.<clinit>(JcfJabberGuestCall.java:75)
        at com.cisco.jabber.guest.sdk.jcf.JcfJabberGuestCall.createInstance(JcfJabberGuestCall.java:505)
        at com.cisco.jabber.guest.sdk.JabberGuestCall.createInstance(JabberGuestCall.java:502)
        at com.jabberguest.sample.call.MainActivity.onCreate(MainActivity.java:91)
        at android.app.Activity.performCreate(Activity.java:8000)
        at android.app.Activity.performCreate(Activity.java:7984)
        at android.app.Instrumentation.callActivityOnCreate(Instrumentation.java:1309)
        at android.app.ActivityThread.performLaunchActivity(ActivityThread.java:3422)
        at android.app.ActivityThread.handleLaunchActivity(ActivityThread.java:3601)
        at android.app.servertransaction.LaunchActivityItem.execute(LaunchActivityItem.java:85)
        at android.app.servertransaction.TransactionExecutor.executeCallbacks(TransactionExecutor.java:135)
        at android.app.servertransaction.TransactionExecutor.execute(TransactionExecutor.java:95)
        at android.app.ActivityThread$H.handleMessage(ActivityThread.java:2066)
        at android.os.Handler.dispatchMessage(Handler.java:106)
        at android.os.Looper.loop(Looper.java:223)
        at android.app.ActivityThread.main(ActivityThread.java:7656)
        at java.lang.reflect.Method.invoke(Native Method)
        at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:592)
        at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:947)
Alexander Stevenson
Hi @ahlam ali,
It seems you may need to add the relevant *.so libraries, perhaps from a directory outside the android project.
