08-04-2016 08:41 AM
Hi There, We've wrapped the Jabber Web SDK into another web application which determines who is going to be called and already knows he or she is going to be called. For that purpose we would like to be able to "Auto-Answer" the Video call, avoiding having to click the "Answer" button as soon as it comes in or is in the "Ringin" state. We tried, coding using: document.getElementById('answerbtn').focus(); document.getElementById('answerbtn').click(); but no luck so far. It is not necessary that the the incoming call "Rings" ; it can be auto answered immediately. Could somebody please help us with a codesnippet on how to accomplish this? Thanks in Advance, Klaas.
08-04-2016 02:11 PM
It sounds like you may be focusing on trying to automate the HTML from one of the sample apps, rather than using the Jabber JavaScript library in the more direct fashion intended. E.g. your web page should be looking to implement a handler for the cwic 'conversationIncoming' event, from there calling 'startConversation' to answer the call, handling 'conversationStarted' event to confirm the call answer has been completed, etc.
E.g. from the sample.html:
function addCwicEventHandlers() {
* Add handlers for conversationStart and conversationIncoming events
$('#phonecontainer')
.bind('conversationStart.cwic', handleConversationStart)
.bind('conversationIncoming.cwic', handleConversationIncoming)
and
function handleConversationIncoming(event, conversation, containerdiv) {
calls.addCall(conversation, containerdiv);
where in the latter you could add something like:
if {configAutoAnswer} {
$call.cwic('startConversation');
08-05-2016 03:29 PM
Hello DSTAUDT,
Again, Thank You Very Much for guiding us in the right direction.
First we would like to comment that the 2 bindings you mentions are already present in de default "sample.js" but it's OK to mention.
Second, in your answer, the last line, an additional parameter is necessary, so the call should read:
$call.cwic('startConversation', answerObject);
and "answerObject" must previously be defined as done in function " incomingAnswerClick(event) ". (We Guessed).
For simplicity we wanted to avoid the video call and added the following:
But now the chrome F12 console, after calling the directory number (dn), indicates
"Cannot set property 'videoDirection' of null" pointing to the line number with the red arrow.
I think we come a long way, but after lots of attempts and trails we could not solve this issue and probably we will have an other hurdle for assigning "answerObject.remoteVideoWindow"
Could you please give us another push ?
Best Regards,
Klaas.
08-09-2016 11:14 PM
Hi There,
We found that the following code implements the AutoAnswer functionality:
Although the voice communication works correctly and is bi-directional, the Video stream is only incoming from the DN how called.
We've added, before the $call.cwic(....) the following:
conversation.videoDirection = 'SendRecv';
conversation.remoteVideoWindow = 'videocallobject';
But it had no effect, thus the Video stream is only incoming and you will notice that the self view is displayed in gray-scale, probably indicating that the video is not outgoing.
If anybody could give us a hint on how to correct this behavior and have a bidirectional video stream we would be very grateful.
Best Regards,
Klaas.
08-11-2016 06:09 PM
Hi There,
Well today we inserted the 2 lines I was writing about in my previous post and the Auto-Answer with duplex video stream works perfectly. So this is the solution:
Best Regards,
Klaas.
