jabberwerx.js running on IE 11
jmennear
I am hoping someone has been working to get Jabber running on IE 11. I am looking for compatibility with Office365.
I see this error when I try to connect to the jabber server:
It says "Exception was thrown at line 15497, column 25 in https://localhost:44301/Scripts/jabberwerx.js 0x80070005 - JavaScript runtime error: Access is denied.".
If I press continue I get an error at aline 16872, co,umn 21:
I went down the path of IE 11 because IE 9 was not allowing the connect to succeed.
Can you help me get past this error?
-john
Geevarghese Cheria
Hi ,
Cisco Jabber capabilities can be accessed from Microsoft Office applications, including Microsoft Outlook and SharePoint. This helps streamline processes and saves time by letting you see a contact’s availability and initiate communications from the application you are using. Cisco provides the same user experience to escalate from presence, to click to communicate as Microsoft.
Cisco Jabber for Windows supports client-side integration with Microsoft Office 365 with the following applications :
Microsoft Office 2013 32 bit
Microsoft Office 2013 64 bit
Microsoft Office 2010 32 bit
Microsoft Office 2010 64 bit
Microsoft Office 2007 32 bit
Microsoft SharePoint 2010
Reference - Microsoft Office 365
Please refer - Jabber and Windows IE 11  for related information.
Thanks and Regards,
Geevarghese
