Launch Jabber SDK from a CS client
sherzhan
Hi, Experts,
My question is how to launch Jabber SDK from a CS client?
Need install Web browser plugin in CS client first?
Sherry
tinghche
Level 5
Level 5
Sherry,
Sorry, not sure what CS client is?
Basically, the Jabber SDK for web will be running from either Windows or Mac browser. If you are looking for somenative client type of SDK, it's not support currently. If you are trying to integrate your web based application, then it can be done as long as the browser plugin is installed..
Howard
