Macro for Beamer controll over RS232 an Romm Kit EQ
I installed a Room Kit EQ and want to send a RS-232 Command to the Beamer when the Device will start up or go in Standby..
I also have installed the Beta Version of Room OS and the Line from The USB to the Beamer is working (Test it with HEX command and Hterm Software.
So i think i only have a Error in my Macro: I get following Error when VC gos in Standby or Turn ON: Unhandled promise rejection {"code":-32602,"message":"Bad usage: Missing or invalid parameter(s)."}
import xapi from 'xapi';
function BeamerON() {
    console.log("Turning on Beamer");
    xapi.Command.SerialPort.PeripheralControl.Send(
      'Command':"02 00 00 00 00 02",
      //'ResponseTerminator' : "\n",
      'ResponseTimeout': 2000
function BeamerOFF() {
    console.log("Turning off Beamer");
      'Command':"02 01 00 00 00 03",
      //;'ResponseTerminator' : "\n",
function registerEventHandlers() {
    // Register for Standby/PowerOn  events
  xapi.status.on('Standby State', (state) => {
    if (state === 'Off') BeamerON();
    if (state === 'Standby') BeamerOFF();
    if (state === 'Halfwake') BeamerON();
function init() {
    registerEventHandlers();
init();
i also try it with following Commands:
      'Command':"02h 00h 00h 00h 00h 02h",
      'Command':"02h 01h 00h 00h 00h 03h",
function init() {
init();
 Someone have a idia waht i miss here? How the Cisco endpoint know how to Use what USB-Port of the Codec EX for Serial Port communication?? (i have tryed all 4 Ports with no effect)
Christian
mfr-6
hi @christian-sifrar
Based on what I found in the docs, I see that arguments for
are different in a docs: https://roomos.cisco.com/xapi/Command.SerialPort.PeripheralControl.Send/ from what you've provided
Could you provide us more details about your setup so we can look deeper at it?
BTW. docs for Send command are available here: https://roomos.cisco.com/xapi/Command.SerialPort.PeripheralControl.Send/
Mateusz Frak NetDevOps | DevNet | Automation
Please mark this post as helpful if it solves your issue, to make this visible for other users, thank you!
FYI
I Solved the issue, the macro was false, here the right one:
        Text:"\x02\x00\x00\x00\x00\x02"
        Text:"\x02\x01\x00\x00\x00\x03"
function init() {
init();
mfr-6
@christian-sifrar
Thank you for sharing the solution!
