Node.js error
joeharb
Level 10
Level 10
I am working on installing Node.js and have it configured.  When I use the phoneconfig get and put in my credentials the process crashes and I get the following:
I am simply putting in the following :  http://IP of Node:1789/phoneconfig/devices?ccmcip={IP of CCM}
I get an authentication request page, put in credentials then the following happens on the node server.
events.js:72
        throw er; // Unhandled 'error' event
Error: getaddrinfo ENOTFOUND
    at errnoException (dns.js:37:11)
    at Object.onanswer [as oncomplete] (dns.js:124:16)
The Hello works with out issue
Joe
Geevarghese Cheria
Hi Joe,
     getaddrinfo is caused because its unable to resolve the domain address. I would request you to check if the domain named could be resolved properly. Also  would request you to refer  How to ... Install the Node Component
Thanks and Regards,
Geevarghese
