placing an outbound call from agent side in REM
exjun
Hello.
Is it possible that  a REM agent can call a REM app running on customer's ios and android devices ?
Would it be possible to do it now, using advanced sdk ?
If not, is there a roadmap to support the feature in the next version of REM ?
Thanks in advance
robdoyle
It is not possible to call out to consumer devices with REM 10.6
The advanced SDK in REM 11 will allow customer's to receive calls on iOS/Android and in browsers.
There is no plan to support V&V call handling from the REM Finesse Gadget.
Rob
Thank you for the response
