Possible to pull daily firmware update status?
jtborgeso
We are trying to help a customer analyze a large number of endpoints (DX, SX, MX, TX and others) and detect which ones have out of date firmware so they can go through the update process.
Is there a library or API somewhere that we can interface with in order to automatically pull this information daily.  We already get firmware information directly from the endpoints, we just need a list to compare them to.
Patrick Sparkman
There is no way to do it automatically, but you can check yourself using the System Overview option within TMS under the Systems tab.  There is a "Software Version" option under General that will return the software version of any selected endpoints or infrastructure.
By the way, this question might be better off in the TelePresence section of the Cisco Support Forums.
Thanks! I will do that.
