Size of CiscoIPPhoneStatusFile not to overlyp buttons on the right side
sbecker2000
to notify some states, I use the CiscoIPPhoneStatusFile to show the status in the call-pane. But when the ftatus is set, it will overlap the buttons on the right side. Is it possible to control the size of the status window?
Thanks in advance
dstaudt
The size of the window is fixed
