Unity Connection Database Proxy: -25582 Network connection is broken
Martin Sloan
While trying to connect with Unity Connection via Informix ODBC, I'm receiving the following error on some CUC systems:
     SQLSTATE=HY000, SQLDriverConnect: -25582 [Informix][Informix ODBC Driver][Informix]Network connection is broken
Out of roughly 20 systems, I'm getting this error on 3.  I've checked that the Proxy service is running and that I have the Remote Administrator Role.  I've tried stopping/restarting the service as well.  I can also telnet to port 20532 on the CUC server from the server I'm attempting to connect with.  Google searches mostly point to DBA forums which aren't a huge help with this appliance model.  Has anyone run into this issue while trying to connect up to the DB proxy service?
Marty
as a side note, you can also get that if the password is set to change at the next login - the lack of specifics in the error message is intentional (security team doesn't want us revealing anything along these lines) - can be a little confusing around the edges, though.
Martin Sloan
This ended up being an expired password issue.  When you're used to '401 Unauthorized', this response sounds much worse than it is!
