xAPI code for sending DTMF to Codec Pro or Webex cloud not functions?
Hello community,
we use a Codec Pro in a meeting room controlled by a third party controler over SSH instead of a RoomNaviagtor or Touch10. This works fine up to a certain point. We want to join a webinar. And for that we have to enter the Panelist code. We tried "xCommand Call DTMFSend CallId: value DTMFString: value Feedback: Audible". We receive a 200/OK from Codec Plus but nothing else. The Codec Plus does not enter the webinar. Any ideas?
Codec Pro, RoomOS 11.14.1.7 (stable) and 11.16.0.28 (beta), Webex cloud registered
Greetings
Sebastian
The problem is solved.
Using "xCommand Webex Join DisplayName: value Number: value ParticipantRole: value Pin: value TrackingData: value" include the PIN.
I have used the command only up to "xCommand Webex Join DisplayName: value Number: value" because this worked for us until now
