The IP Phone Service API provides a general API for displaying text and images on the phone, for details about how to use the API see the 'IPPS Development Notes' here:
Also check the IPPS SDK at the same link for various sample applications demonstrating usage of the API.
Beyond the details of the usage of IPPS, it sounds like you will need automation that is linked into Contact Center, for which you will want to explore the available APIs here:
Goal: Provide a simple User Interface to control, modify and customize your Webex Desk Video device.Install time: around 5 minutes (upload the UI and macro)
What can you do?
Settings
Camera ExposurePan/tiltSelf-view on/off + small/full ...
view more
Okay, guilty as charged for creating a click bait subject. I love Python. But there are some things about Python that can be annoying if you're just starting out as a Python programmer. Let's tackle a few of them so you don't suffer from the mistakes I ha...
view more
Demo - Webex Video device Virtual Lamp integration
Objective
Show how easy it is to create a virtual lamp and integrate it with a Webex Video device or bot. Create your own lamp using the virtual lamp bot make it create a ...
view more
Team,As I'm using a lot of virtual environments with PIPENV, it became harder to keep track of the environments that I have setup. And that was the reason to create this script which:
List all of your (pipenv) virtual environments
Select one
Change...
view more
