Cme with b-acd + TOD scrip
peepo1ccna
Hi All
I'm new in scipt and have problem about b-acd from Cme with b-acd scrip not hunt  everything OK . but I need to use tod scrip refer from(https://developer.cisco.com/site/collaboration/call-control/voice-gateway/documentation/) it work.
I try to use tod + aa script but not work anyone can suggest me how to intergrate it.
Please help me!
application
service aa flash:app-b-acd-aa-2.1.2.3.tcl
  paramspace english index 1
  param number-of-hunt-grps 2
  param menu-timeout 6
  param dial-by-extension-option 5
  param handoff-string aa
  paramspace english language en
  param max-time-vm-retry 2
  param max-extension-length 4
  param aa-pilot 7700
  paramspace english location flash:
  param second-greeting-time 60
  param welcome-prompt _bacd_welcome.au
  param call-retry-timer 15
  param max-time-call-retry 600
  param voice-mail 5000
  param service-name queue
service queue flash:app-b-acd-2.1.2.3.tcl
  param queue-len 15
  param aa-hunt1 7777
  param aa-hunt2 8888
  param queue-manager-debugs 1
service tod flash:/tod.tcl
  param end 17:00
  param start 08:00
  param prefix 7700
dial-peer voice 300 pots
service tod
destination-pattern 02.......
incoming called-number 027515577
port 0/0/0
forward-digits all
dial-peer voice 310 pots
service aa
incoming called-number 7700
port 0/0/0
forward-digits all
dial-peer voice 320 pots
service aa
destination-pattern 77..
port 0/0/0
forward-digits all
6 Replies 6
Raghavendra G V
Hi manapath,
You can try to handoff to bacd script as below from tod script instead of leg setup.
handoff appl leg_incoming $aaName -s "ISN"
call close
Raghavendra
Hi Raghavendra
From tod script I have to do like this ?
# This tcl script provides Time of Day Routing
proc init { } {
    global param
proc act_Setup { } {
    leg setupack leg_incoming
    call close
    set dnis [infotag get leg_dnis]
    set now [clock format [clock seconds] -format %R]
    puts "now $now"
    set block 0
    if {[infotag get cfg_avpair_exists start] && [infotag get cfg_avpair_exists end]} {
      set start [infotag get cfg_avpair start]
      set end [infotag get cfg_avpair end]
      set cc [string compare $start $end]
      puts "start $start end $end cc $cc"
      if {$cc} {
        if {$cc==1} {
It still not work.
when you say did not work means it did not handoff to aa script ? did you changed the aa script name ?
Raghavendra
HI Raghavendra
I try to change llike you suggest but not work , I'm not sure that I change in the right point, if you not mind please help me to check the script(tod_modify).
thankyou.
please go through the TCL IVR programming guide from below link
Syntax
handoff {appl | callappl} {legID | info-tag} [{legID2 | info-tag2} ...] {app-name | <handle>} [-s
<argstring>]
Arguments
• appl | callappl—Specific handoff command desired. The only difference is that appl does not
provide a return value, callappl does.
• legID | infotag—The call leg ID to hand off to the destination. For more information about info-tags,
see Chapter 4, “Information Tags.”
• app-name | <handle>—The application name or handle.
• -s <argstring>—Information to pass to another application instance.
Raghavendra
