Modify Request-URI, To Header, From Header and Contact Header
Hello all,
first of all i am very new to SIP Normalization Scripts and LUA programming.
I am trying to modify the Request-URI, To Header, From Header and Contact Header with a SIP Normalization script. But, without much luck so far and i am looking for any help or tip to get my script working.
I am able to modify the Requst-URI and the To Header one at a time but not all of them in one go.
This is my script which i am working on:
M = {}
trace.enable()
function M.inbound_INVITE(msg)
    local mwi_number_length = scriptParameters.getValue("MWI-Number-Length") -- MWI-Number-Length equals to 7
-- Get the SIP Request
    local method, ruri, version = msg:getRequestLine()
-- Adjust SIP Request URI
    -- Get the first digits of the Request URI to form the new Called number
        local dnis_start = string.find(ruri, "%d")
        local dnis_end = dnis_start+mwi_number_length-1
        local dnis = string.sub(ruri, dnis_start, dnis_end)
    -- Get the Right Hand Side from the Request URI
        local host_start = string.find(ruri, "\@")
        local host_end = string.find(ruri, "%d", -1)
        local host = string.sub(ruri, host_start, host_end)
        local ruri_new = "sip:" .. dnis .. host
    -- Tracing
        trace.format("New DNIS is %s:%s", dnis)
        trace.format("New RURI is %s:%s", ruri_new)
    -- Set the new Request URI
        msg:setRequestUri(ruri_new)
end
trace.enable()
-- Adjust SIP To Header
    -- Get the SIP To Header
        local to = msg:getHeader("To")
    -- Extract DNIS from SIP To Header
        local to_dnis_start = string.find(to, "%d")
        local to_dnis_end = to_dnis_start+mwi_number_length-1
        local to_dnis_new = string.sub(to, to_dnis_start, to_dnis_end)
    -- Extract RHS from SIP To Header
        local to_rhs = string.match(to, "\@.*")
    -- Create New SIP To Header
        local to_new = "<sip:" .. to_dnis_new .. to_rhs
    -- Tracing
        trace.format("New To DNIS is %s:%s", to_dnis_new)
        trace.format("New To Header is %s:%s", to_new)
    -- Set the new SIP To Header
        msg:modifyHeader("To", to_new)
end
return M
This is the original SIP Invite:
INVITE sip:91249874955566677788@10.123.255.145:5060;transport=udp SIP/2.0
Via: SIP/2.0/UDP 10.122.185.5:5060;branch=z9hG4bKQv9ZAYlmXawDkxKenpWp9g~~21
Max-Forwards: 70
To: <sip:91249874955566677788@10.123.255.145:5060>
Call-ID: 143871259893526@10.122.185.5
CSeq: 100 INVITE
Content-Length: 190
Contact: <sip:9124980@10.122.185.5:5060;transport=udp>
Content-Type: application/sdp
Allow: INVITE, BYE, CANCEL, ACK, REFER, SUBSCRIBE, NOTIFY, INFO
Cisco-Gcid: F9F41197-014E-1000-5EE4-BDDE9F0E867D
The modified SIP Invite should look like this:
INVITE sip:9124987@10.123.255.145:5060;transport=udp SIP/2.0
Max-Forwards: 70
To: <sip:9124987@10.123.255.145:5060>
From: <sip:4955566677788@10.122.185.5>;tag=ds2f74cdd
CSeq: 100 INVITE
Content-Length: 190
Contact: <sip:4955566677788@10.122.185.5:5060;transport=udp>
Any help or tip is welcome!
/Robert
Mark Stover
The script only gets invoked once per message. This is different from how CUBE handles a list of Normalization rules.
What you have to do is combine both 'functions' in a single M.inbound_INVITE() procedure. You can probably reuse a lot of code since you are trying to set the Request URI and TO headers to essentially the same thing.
Mark
Mark Stover
Mark
Hi mark,
I got my script working now that i am using only one 'function'. Thanks for your help!
Here is my working script:
M = {}
-- Get the MWI On/Off Numbers as Parameters from the CUCM Trunk Page
    mwiOnNumber = scriptParameters.getValue("MWI-On-Number")
    mwiOffNumberNumber = scriptParameters.getValue("MWI-Off-Number")
-- Get the SIP Request-URI
-- SIP Request-URI: INVITE sip:91249884955566677788@10.123.255.145:5060 SIP/2.0
        -- Extract the Protocol Handler from SIP Request-URI
        ruriProtHandlerStart = string.find(ruri, "%a")
        ruriProtHandlerEnd = string.find(ruri,"\:")
        -- Set the Protocol Handler from SIP Request-URI
        ruriProtHandler = string.sub(ruri, ruriProtHandlerStart, ruriProtHandlerEnd)
-- Extract DNIS from SIP Request-URI
        dnisStart = string.find(ruri, "%d")
        mwiNumberLength = string.len(mwiOnNumber)
        dnisEnd = dnisStart+mwiNumberLength-1
        -- Set the New DNIS
        dnis = string.sub(ruri, dnisStart, dnisEnd)
-- Extract ANI from SIP Request-URI
        aniStart = dnisStart+mwiNumberLength
        aniEnd = string.find(ruri, "\@")
        ani = string.sub(ruri, aniStart, aniEnd-1)
        -- Set the New ANI
        aniNew = "\+" .. ani
-- Extract the Right Hand Side from SIP Request-URI
        ruriRhs = string.match(ruri, "\@.*")
        -- Set the new Right Hand Side from SIP Request-URI
        ruriNew = ruriProtHandler .. dnis .. ruriRhs
--  Get the SIP To Header: To: <sip:91249884955566677788@10.123.255.145>
        -- Extract the Protocol Handler from SIP To Header
        toProtHandlerStart = string.find(to, "\<")
        toProtHandlerEnd = string.find(to, "\:")
        toProtHandler = string.sub(to, toProtHandlerStart, toProtHandlerEnd)
        -- Extract the Right Hand Side from SIP To Header
        toRhsTag = string.match(to, "\@.*")
        toNew = toProtHandler .. dnis .. ruriRhs .. ">"
-- Get the SIP From Header: From: <sip:9124980@10.122.185.4>;tag=D6F709E8-144
    from = msg:getHeader("From")
        -- Extract the Protocol Handler from SIP From Header
        fromProtHandlerStart = string.find(from, "\<")
        fromProtHandlerEnd = string.find(from, "\:")
        fromProtHandler = string.sub(from, fromProtHandlerStart, fromProtHandlerEnd)
        -- Extract the Right Hand Side from SIP From Header
        fromRhsTag = string.match(from, "\@.*")
        -- Set the new SIP From Header
        fromNew =  fromProtHandler .. aniNew .. fromRhsTag
-- Get the SIP Contact Header: Contact: <sip:9124980@10.122.185.4:5060>
    contact = msg:getHeader("Contact")
        -- Extract the Protocol Handler from SIP Contact Header
        contProtHandlerStart = string.find(contact, "\<")
        contProtHandlerEnd = string.find(contact, "\:")
        contProtHandler = string.sub(contact, contProtHandlerStart, contProtHandlerEnd)
        -- Extract the Right Hand Side from SIP Contact Header
        contRhsTrans = string.match(contact, "\@.*")
        -- Set the new SIP Contact Header
        contNew =  contProtHandler .. aniNew .. contRhsTrans
-- Get the SIP Remote-Party-ID Header: Remote-Party-ID: <sip:9124980@10.122.185.4>;party=calling;screen=no;privacy=off
-- Only needed when the CUE is connecteed to CUCM through an IP-IP Gateway
    rpid = msg:getHeader("Remote-Party-ID")
        -- Extract the Protocol Handler from SIP Remote-Party-ID Header
        rpidProtHandlerStart = string.find(rpid, "\<")
        rpidProtHandlerEnd = string.find(rpid, "\:")
        rpidProtHandler = string.sub(rpid, contProtHandlerStart, contProtHandlerEnd)
        -- Extract the Right Hand Side from SIP Remote-Party-ID Header
        rpidRhsTrans = string.match(rpid, "\@.*")
        -- Set the new SIP Remote-Party-ID Header
        rpidNew =  rpidProtHandler .. aniNew .. rpidRhsTrans
-- Check if the DNIS equals to the MWI On or Off Number
if dnis == mwiOnNumber then
    -- If DNIS equals to the MWI On Number then return the new Headers
    msg:setRequestUri(ruriNew) -- Return New Request URI
    msg:modifyHeader("To", toNew) -- Return New To Header
    msg:modifyHeader("From", fromNew) -- Return New From Header
    msg:modifyHeader("Contact", contNew) -- Return New Contact Header
    msg:modifyHeader("Remote-Party-ID", rpidNew) -- Return New Remote-Party-ID Header, Only needed when the CUE is connecteed to CUCM through an IP-IP Gateway
elseif dnis == mwiOffNumberNumber then
    -- If DNIS equals to the MWI Off Number then return the new Headers
else
    -- If DNIS is something other than the MWI Numbers leave the Headers as is
end
end
return M
