Call Control
Intro to Ansible
Good Documentation
The Great Selenelion
>> View previously featured conversations <<
Hi,I am trying to use TCL IVR to get my 2431/2921 VGWs to Subscribe to SIP registration events after successfully Registering  with the SIP Proxy on our IMS system.  Currently the VGW SIP stack does not support Subscribe/Notify for reg in native IOS ...
Hello DevCommunity,I have two questions, which I cannot answer due to lack of DevExperience. I hope you can help out?1. If a call iis opened via TAPI, is the call dialed by the user's hw phone, or is it initiated by CUCM and the phone is just connect...
Agor85 by • Level 3
  • 1482 Views
  • 1 replies
Hello All,One of our customer is using Cisco UCM 8.6.2 and we would like to integrate our .Net application with it to get information from UCM such as Caller ID, Call Duration, Call Status, Call Start time & End time etc.I have searched for the SDK o...
bitspromax by • Community Member
  • 970 Views
  • 1 replies
Another unexpected behavior when the application's timer handling is less than perfect.See code below. When timer stop call_timer0 is executed without a call_timer0 running, even the named_timer, that should not be affected, is stopped. So the applic...
Hi,CUCM Version - 10.5.2 Cisco Jtapi version 10.0(1.10000)-2Cisco Jtapi version 10.0(1.10000)-2OS - Windows 2008 Standard R2 - 64 BitUsing Cisco Test Tool when we are adding call observer to phones/terminals. Some of them are becoming green but some ...
Hi,Is it possible to call another TCL application from with in tcl app?or otherwise is it possible to assign two TCL Application to single dial peer to execute in series. i.e once first application is finished then second executes.ThanksAshish
AshG by • Level 4
  • 3248 Views
  • 11 replies
in leg setup we can specify dialpeerHandle using switch -d. , However I am not sure what it is. its definitely not Dial Peer Tag number as I have tried that.leg setup {destination | array-of-destinations} callinfo [legID | info-tag] [-g <GTDHandle>] ...
AshG by • Level 4
  • 837 Views
  • 1 replies
I have gone through all discussion regarding this error in forum but don't find any specific reason for this error.Take example - I am asking phone to fetch a URL from server using JTAPI senddata but getting this error. Can you please tell us what co...
