NotifyXccConnectionData and ResponseXccConnectionAuthorize?
jboga
Level 5
Level 5
I'm developing using Cisco's UC Gateway Services.
I managed to have a working SOAP Server without a problem. Right now I've tested the SolicitXccProbing/ResponseXccProbing and doing a RequestXccConnectionRelease.
However, I'm trying yo test a NotifyXccConnectionData and ResponseXccConnectionAuthorize with block or release but it's not working. The routers gives an HTTP error getting the response.
<?xml version="1.0" ?>
<SOAP:Envelope xmlns:SOAP="http://www.w3.org/2003/05/soap-envelope">
        <SOAP:Body>
                <SolicitXccConnectionAuthorize xmlns="http://www.cisco.com/schema/cisco_xcc/v1_0">
                        <msgHeader>
                                <transactionID>66A5D6D8:3392</transactionID>
                                <registrationID>62959620:XCC:QCE:66</registrationID>
                        </msgHeader>
                        <callData>
                                <callID>139</callID>
                                <state>ACTIVE</state>
                        </callData>
                        <connDetailData>
                                <connData>
                                        <connID>417670</connID>
                                        <state>AUTHORIZE_CALL_ATTEMPT</state>
                                </connData>
                                <guid>800B79D7-3CDD-B146-7F00-6802AC1EC9A6</guid>
                                <callingAddrData>
                                        <type>E164</type>
                                        <addr>CALLINGNUMBER</addr>
                                </callingAddrData>
                                <calledAddrData>
                                        <type>E164</type>
                                        <addr>CALLEDNUMBER</addr>
                                </calledAddrData>
                                <origCallingAddrData>
                                        <type>E164</type>
                                </origCallingAddrData>
                                <origCalledAddrData>
                                        <type>E164</type>
                                </origCalledAddrData>
                                <connIntfType>CONN_H323</connIntfType>
                                <mediaData>
                                        <type>VOICE</type>
                                </mediaData>
                                <connIntf>IPADDRESS</connIntf>
                                <connDirectionType>INCOMING</connDirectionType>
                        </connDetailData>
                </SolicitXccConnectionAuthorize>
        </SOAP:Body>
</SOAP:Envelope>
The response is:
<?xml version="1.0"?>
<soapenv:Envelope xmlns:soapenv="http://www.w3.org/2003/05/soap-envelope">
    <soapenv:Header/>
    <soapenv:Body>
        <ResponseXccConnectionAuthorize xmlns="http://www.cisco.com/schema/cisco_xcc/v1_0">
            <msgHeader>
            </msgHeader>
            <action>block</action>
        </ResponseXccConnectionAuthorize>
    </soapenv:Body>
</soapenv:Envelope>
This is the debug result that I get using a debug wsapi xcc messages
Nov 18 17:58:52.409: //WSAPI/XCC/OUTGOING_MESSAGE:: msg_type[19]  SolicitXccConnectionAuthorize
Nov 18 17:58:52.409: registrationID 62959620:XCC:QCE:66
Nov 18 17:58:52.409: callID: 139
Nov 18 17:58:52.409: state 2
Nov 18 17:58:52.409: connID: 417670
Nov 18 17:58:52.409: state: 2
Nov 18 17:58:52.437: //WSAPI//INCOMING_RESPONSE:: type 1  HTTP_ERROR:
Nov 18 17:58:52.437: http_error_code -3
Am I doing something wrong in the response? Do I need to include more information?
Best regards,
Raghavendra G V
Sorry for the late reply. If you are still facing the issue, could you please collect the logs with below debugs enabled.
debug wsapi infra all
debug wsapi xcc all
debug ip http all
Raghavendra
Raghavendra,
I'll do this during the week and let you know.
Best regards,
-- Jose
Belevtsov
did you find what the problem was? dealing with the same 10 years later...
