Override Call Park Reversion using TAPI?
Mark Knepper
I have several operators that need a variable amount of time for reversion -- can TAPI override the Clusterwide setting for Call Reversion Timer. I am using 7965s with CUCM 8.6 and the individual Call Park Reversion setting for the line appears to only apply to 89xx and 99xx phones.
Mark
Geevarghese Cheria
Hi Mark,
  The Park Monitoring feature allows you to monitor the status of parked calls. This feature improves the user experience of retrieving the parked calls. When TAPI receives a parked call notification, a call representing the parked call is generated, and the call is set to CONNECTED INACTIVE state. The parked call is set to IDLE when it is retrieved or forwarded to Park Monitoring Forward No Retrieve Destination.
Reminder -indicates the park monitoring reversion timer for the parked call has expired.
Please refer Park Monitoring for more details.
Thanks and Regards,
Geevarghese
