VXML DTD error
amit.bidkar11
Community Member
I am getting:
CALL_ERROR; http://HTTP-SERVER/quickstart/
   at line 13: Element <block> is not used according to DTD
My VXML Code:
?xml version="1.0"?>
  <vxml version="2.0">
    <var name="counter" expr="0"/>
    <var name="number" expr="'.'"/>
    <var name="test" expr="1"/>
    <form id="mainform">
        <field name="getdigit" type="digits?length=1">
            <grammar type="application/grammar+regex">[1234567890*]</grammar>
    <block>
            <if cond="test==1">
                <prompt bargein="false">
                    Please enter 10 digits mobile number.
                </prompt>
            </if>
  </block>
            <filled>
                <var name="escape" expr="getdigit"/>
                <if cond="escape=='*'">
                    <goto next="#mainform"/>
                    <else>
                        <var name="number" expr="number + '.' + getdigit"/>
                        <var name="counter" expr="counter+1"/>
                        <if cond="counter==10">
                            <var name="result" expr="number"/>
                        </if>
                        <else>
                            <var name="test" expr="0"/>
                        </else>
                    </else>
                </if>
            </filled>
        </field>
    </form>
</vxml>
Plz Help me out......................
Raghavendra G V
Hi Amit,
i think <block> should be used inside <form> element, but looks like you are using inside <filed> element.
Raghavendra
Hi Raghavendra,
Thank You. I resolved the problem.
Thank You,
Amit Bidkar
On Wednesday 04 February 2015 11:01 AM, Raghavendra Gutty Veeranagappa
