06-05-2018 07:33 AM - edited 03-20-2019 10:12 PM
Hi. I have Catalyst 2960-X-48FPS-L Switch. I upgraded image on 15.2.6E1. But switch stuck on post during.
rwsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspssssssss
% Front-end Microcode IMG MGR: address 0, PROGRAM failed
% Front-end Microcode IMG MGR: unable to program device: 0
% Front-end Microcode IMG MGR: malformed microcode cache
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Failed
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
06-05-2018 02:17 PM
Can you try to pull the power cable and see if this works? Do NOT use the "reboot" command.
06-05-2018 11:35 PM
I cant do anything.
Here the image
06-06-2018 03:18 AM
08-07-2018 05:37 AM
09-06-2018 06:41 AM
09-06-2018 07:21 AM - edited 06-25-2021 05:33 PM
CSCvf24186
Try and pull the power cord. No, I am not f**king joking.
09-06-2018 07:38 AM
Hi Leo,
i had tried everything, also trying to load with old IOS, but no chance. Only thing that solved was RMA the switch with Cisco :-( .
10-16-2018 04:44 AM
I also have the same problem 2960x 48LPS-L!!!!
11-28-2018 04:35 AM - edited 11-28-2018 04:47 AM
We're hitting this bug as well. Upgraded to 15.2.4E6
We had them on v02 and v03 series, we have also v01, v04, v05, v06 and v07 swiches they were not affected.
06-25-2021 02:32 PM
THIS IS THE SOLUTION - DON'T WASTE TIME JUST DO IT
10-17-2018 04:37 AM
10-18-2018 06:00 AM
11-04-2018 06:33 AM
I had the same issue when i wanted to upgrade from firmware 150-2.EX5 to 152-6.E2.
This is my workaround:
After this procedure some of our switches can boot with the new firmware right away, some other switches needed one reboot if boot stucked again.
I could upgrade all of my switch with this workaround.
Note that our switches are working in standalone mode, not in stack mode, but maybe this can help you somehow.
01-21-2019 05:32 AM
1. Press mode button to enter recovery mode
2. Use usb to copy the 15.2.4E6 and info to flash drive
3. Use set command to view the boot
4. Boot= flash:/xxx15.2.4E6.bin
5.Run boot to load the image
6. Wait -> the fan turn on again
7. Check config and wri
