2960X Stuck at Post
emrecastle123
Hi. I have Catalyst 2960-X-48FPS-L Switch. I upgraded image on 15.2.6E1. But switch stuck on post during.
rwsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspssssssss
% Front-end Microcode IMG MGR: address 0, PROGRAM failed
% Front-end Microcode IMG MGR: unable to program device: 0
% Front-end Microcode IMG MGR: malformed microcode cache
POST: MA BIST : Begin
POST: MA BIST : End, Status Passed
POST: TCAM BIST : Begin
POST: TCAM BIST : End, Status Passed
POST: ACT2 Authentication : Begin
POST: ACT2 Authentication : End, Status Failed
Waiting for Stack Master Election...
POST: Thermal, Fan Tests : Begin
26 Replies 26
ChrisTsangCTS
I face the same problem when upgrade to 15.2.6E2 and the fan not work.
1. Press mode button to enter recovery mode
2. Use usb to copy the 15.2.4E6 and info to flash drive
3. Use set command to view the boot
4. Boot= flash:/xxx15.2.4E6.bin
5.Run boot to load the image
6. Wait -> the fan turn on again
7. Reset the boot to old image
8. wri
oiist0001
Hello! Have you solved this problem?
Solved, but only wake up the fan and rollback to 15.2(2)E7
pimentelr1
Facing same issue:
File "flash:c2960x-universalk9-mz.152-7.E4.bin" uncompressed and installed, entry point: 0x3000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2960X Software (C2960X-UNIVERSALK9-M), Version 15.2(7)E4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Mon 08-Mar-21 11:26 by prod_rel_team
Initializing flashfs...
Using driver version 4 for media type 1
mifs[7]: 12 files, 1 directories
mifs[7]: Total bytes : 1806336
mifs[7]: Bytes used : 833536
mifs[7]: Bytes available : 972800
mifs[7]: mifs fsck took 0 seconds.
mifs[7]: Initialization complete.
mifs[8]: 2 files, 1 directories
mifs[8]: Total bytes : 3870720
mifs[8]: Bytes used : 1213440
mifs[8]: Bytes available : 2657280
mifs[8]: mifs fsck took 1 seconds.
mifs[8]: Initialization complete.
mifs[9]: 5 files, 1 directories
mifs[9]: Total bytes : 258048
mifs[9]: Bytes used : 8192
mifs[9]: Bytes available : 249856
mifs[9]: mifs fsck took 0 seconds.
mifs[9]: Initialization complete.
mifs[10]: 5 files, 1 directories
mifs[10]: Total bytes : 258048
mifs[10]: Bytes used : 8192
mifs[10]: Bytes available : 249856
mifs[10]: mifs fsck took 0 seconds.
mifs[10]: Initialization complete.
mifs[11]: 9 files, 2 directories
mifs[11]: Total bytes : 122185728
mifs[11]: Bytes used : 52085248
mifs[11]: Bytes available : 70100480
mifs[11]: mifs fsck took 1 seconds.
mifs[11]: Initialization complete.
...done Initializing flashfs.
Checking for Bootloader upgrade..
Boot Loader upgrade not needed(v)
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
extracting front_end/front_end_ucode_info (43 bytes)
Software version is different so extracting
the whole bundle
extracting ucode_info (76 bytes)
front_end/ (directory)
extracting front_end/fe_type_9 (82197 bytes)
Front-end Microcode IMG MGR: Installed 3 image(s) in cache:
Front-end Microcode IMG MGR: found microcode images for 3 devices.
Image for front-end 0: flash:/front_end_ucode_cache/ucode.0
Image for front-end 7: flash:/front_end_ucode_cache/ucode.0
Image for front-end 14: flash:/front_end_ucode_cache/ucode.0
Front-end Microcode IMG MGR: Preparing to program device microcode...
Front-end Microcode IMG MGR: Preparing to program device[0]...29204 bytes.
Front-end Microcode IMG MGR: Programming device 0...rwRrrrrrrwsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspssssssss
POST: ACT2 Authentication : End, Status Passed
Will attempt @Leo Laohoo 's solution of unplugging and waiting to see if it boots and communicate results.
@Leo Laohoo's  solution works:
Front-end Microcode IMG MGR: Programming device 0...rrrrrrwsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspsssssssspwRr!
Front-end Microcode IMG MGR: Microcode programming complete for device 0.
Front-end Microcode IMG MGR: Microcode programming complete.
{HAD TO UNPLUG POWER CORD HERE - as per @Leo Laohoo's recommendation - thanks Leo .}
CPU rev: B
Image passed digital signature verification
Board rev: 24
Testing DataBus...
Testing AddressBus...
Testing Memory from 0x00000000 to 0x1fffffff.../
Xmodem file system is available.
Base ethernet MAC Address: 2c:0b:e9:e2:a3:80
The password-recovery mechanism is enabled.
APM USBUSB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 12 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 833536
mifs[5]: Bytes available : 972800
mifs[5]: mifs fsck took 1 seconds.
mifs[6]: 2 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1213440
mifs[6]: Bytes available : 2657280
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 9 files, 2 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 52085248
mifs[9]: Bytes available : 70100480
mifs[9]: mifs fsck took 52 seconds.
...done Initializing Flash.
Loading "flash:c2960x-universalk9-mz.152-7.E4.bin"...Verifying image flash:c2960x-universalk9-mz.152-7.E4.bin.........................................................................................................................................................................................................................................................................................................................................................................................................................Image passed digital signature verification
executing...
cisco Systems, Inc.
POST: Thermal, Fan Tests : End, Status Passed
POST: PortASIC Stack Port Loopback Tests : Begin
POST: PortASIC Stack Port Loopback Tests : End, Status Passed
POST: PortASIC Port Loopback Tests : Begin
POST: PortASIC Port Loopback Tests : End, Status Passed
POST: EMAC Loopback Tests : Begin
POST: EMAC Loopback Tests : MAC Loopback Passed
POST: EMAC Loopback Tests : PHY Loopback Passed
POST: EMAC Loopback Tests : End, Status Passed
Election Complete
Switch 1 booting as Master
Waiting for Port download...Complete
Initializing Port Extension Feature Support...
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C2960X-48FPS-L (APM86XXX) processor (revision L0) with 524288K bytes of memory.
Processor board ID FCW2043B6V8
Last reset from power-on
1 Virtual Ethernet interface
1 FastEthernet interface
52 Gigabit Ethernet interfaces
2 Ten Gigabit Ethernet interfaces
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 2C:0B:E9:E2:A3:80
Motherboard assembly number : 73-16691-05
Power supply part number : 341-0527-02
Motherboard serial number :
Power supply serial number :
Model revision number : L0
Motherboard revision number : A0
Model number : WS-C2960X-48FPS-L
Daughterboard assembly number : 73-14200-03
Daughterboard serial number :
System serial number :
Top Assembly Part Number : 68-100469-01
Top Assembly Revision Number : C0
Version ID : V04
CLEI Code Number : CMMLN00ARC
Daughterboard revision number : A0
Hardware Board Revision Number : 0x18
Switch Ports Model SW Version SW Image
* 1 54 WS-C2960X-48FPS-L 15.2(7)E4 C2960X-UNIVERSALK9-M
WARNING: Command has been added to the configuration using a type 0 password. However, type 0 passwords will soon be deprecated. Migrate to a supported password type
Press RETURN to get started!
{HAD TO UNPLUG POWER CORD AGAIN HERE - 3rd time's the charm.}
CPU rev: B
Board rev: 24
Testing DataBus...
USB EHCI 1.00
USB Console INIT
executing...
cisco Systems, Inc.
Election Complete
export@cisco.com.
Version ID : V04
Switch is gucci now
supportgns
I ran into this same issue this week when trying to update a WS-2960X-48LPS-L to 15.2(7)E4. It always ended with the microcode error and got stuck in POST.
Followed @Leo Laohoo advice, pulled the power cord and plugged into the switch again. Repeated this process 4 times and voila. Yeah, our switch finally came up again and successfully upgraded to latest version. Thanks Leo!
Now what worries me is that I had previously updated another 8 2960-X switches to the same version 15.2(4)E7 (the one recommended by Cisco, BTW) and none of them ran into any trouble during the update. Any ideas about what could have happened?
I had same in new IOS c2960x-universalk9-mz.152-7.E4.bin so I deleted in rommon then boot from old IOS.
I transferred new IOS again from USB (usbflash0: ) and  verified IOS by MD5.  it is working now with new IOS.
Switch#copy usbflash0: flash:
Source filename []? c2960x-universalk9-mz.152-7.E4.bin
Destination filename [c2960x-universalk9-mz.152-7.E4.bin]?
Copy in progress...CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC
26767360 bytes copied in 392.115 secs (68264 bytes/sec)
Switch#verify /md5 flash:c2960x-universalk9-mz.152-7.E4.bin ?
  WORD  Expected md5 signature
  <cr>
Switch#verify /md5 flash:c2960x-universalk9-mz.152-7.E4.bin eb51e6a5f434c5a0ff6f321dcc0dd993
.......................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Done!
Verified (flash:c2960x-universalk9-mz.152-7.E4.bin) = eb51e6a5f434c5a0ff6f321dcc0dd993
Switch#
Have the same problem with one of my switches:
I tried unplugged power cord, firmware before upgrade 152-7 E5, also i tried 15.2.2.E9 and 15.2.4.E6 like in CSCvf24186 described.
It's one of the oldest ones I have wtih Serial FCW18..... . The other Switches with FCW19... or FCW20... did the Update great with one power-reset.
ACT2 Authentication is Passed.
Maybe someone have another hint for me?
Contact Cisco TAC and organize for an RMA.
I'll give it a try, but I don't have a contract with cisco
In the meanwhile I checked if it's a counterfeit Product with this Documents:
https://labs.f-secure.com/assets/BlogFiles/2020-07-the-fake-cisco.pdf
https://www.cisco.com/go/identifycounterfeit
I can't find any hint for a counterfeit Product.
prints, holographic, everything like expectet. Serial-Numbers in Rommon and on boards are also matching.
Let's see what Cisco TAC will say.
joey.debra
A customer of ours has an older network in an older building that will be demolished in less than two years but they needed to expand their current 2960X network without having to upgrade to newer switches so they bought a bunch of remanufactured 2960X switches.
They all came with an older 15.0 version and the first one I tried upgrading to the recent recommended version 15.2.7E5 I of course ended with doing reload instead of unpowering.
Then after reboot I ran into this microcode failure thing.
I then found this post and the cisco bug and found that you could use an in between version 15.2.4E6 and had to load it using rommon and xmodem...   Then setting the boot variable and unplugging replugging did not help but the switch got stuck at the exact same spot in the rrrrrrrrwsssssspsss.. part.
After a few times trying and failing I booted the switch into rommon by holding the button and then just booting the image from there and that seems to fully program the microcode correctly.  However it still got stuck at POST: Thermal, Fan Tests : Begin
After another pulling of the plug it finally started up in that firmware blowing on full fan the whole time until the boot completed.  Now back onto the most recent recommended version and hope this one will succeed this time.
There is a "growing" market of counterfeit 2960X.
One of the easiest method to determine if the switch is counterfeit is to pop the lid and look underneath the motherboard.  Counterfeit 2960X have a crude "daughter card" soldered to main motherboard.
This daughter card allows the counterfeit switch to bypass the IOS image verification stage and fools the OS that the motherboard is legitimate.  This daughter card is programmed specifically to one particular IOS version.  Upgrading to different version and the switch will not boot due to POST error.
