CCP and 1941 secure discovery problem
RedCr1minal
Hi everyone!
I have two 2811 and one 1941 in my home lab.
I want to make a secure connection between 1941 and CCP and i faild.
here are the config on the router:
Spoiler
Current configuration : 1970 bytes
! Last configuration change at 22:54:29 UTC Tue Apr 24 2018 by cisco
version 15.7
hostname R3
boot-start-marker
boot-end-marker
aaa new-model
aaa group server tacacs+ TA_SERVER
server-private 192.168.111.11 key cisco123
aaa authentication login AUTHENTICATION group TA_SERVER local
aaa authorization exec AUTHORIZATION group TA_SERVER local
aaa session-id common
clock timezone UTC 3 0
ip domain name localhost
ip cef
no ipv6 cef
license udi pid CISCO1941/K9 sn FHK144076SF
username cisco privilege 15 secret 5 $1$WHDP$SELnwVQnhuf2lnshCTlq40
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 172.16.1.3 255.255.255.0
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 172.16.0.3 255.255.255.0
duplex auto
speed auto
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 172.16.1.2
ip route 192.168.111.0 255.255.255.0 172.16.1.2
ip route 192.168.112.0 255.255.255.0 172.16.0.1
ip ssh version 2
ipv6 ioam timestamp
control-plane
Nothing really special, huh. When i try to discover by non-secure way, everything is good. But when i do secure connection, i get:  Discovery could not be completed because security certificate was rejected. See help for more information.
i generated an rsa keys, 1024 and 2048 bits. I made a "crypto key zeroize" and "no crypto pki trustpoint TP-self-signed-4228565719". Nothing helps. But with my both 2811 everything works from the first touch.
What can be the problem?
UPDATE:
I use cisco CCP 2.8 desktop version.
0 Replies 0
