CSCsi78581 - Hulc LED Process has even higher CPU (20%) running "fixed" version 15.2(2)E
bcoverstone
A known good fix for the CPU issue was listed as version 15.2(2)E.
However, I have found that this version has even a higher CPU usage of 20% than the original bug indicated at 15%.
Does anyone know a fix for this?
16 Replies 16
I have tried several versions and the best one I've found is 15.2(2)E, even though it still sits around 20%.  Your CPU results will probably vary since we aren't sure what triggers this bug.  My switch is about 60% populated with 1500 IPv4 routing entries.  Based on other versions I've tried, 20% is low.
tkong
On 3750s this bug fix worked for me. I went from 15.0(2)SE9 to 15.0(2)SE7 then finally to 15.0(2)SE5. The last version worked. 15.0(2)SE5. I also noticed this is more of a issue with stacked switches. Standalone switches do not exhibit this exact behavior. See before and after sorts below on 5 stacked switches (mix of 3750X and 3750G)...
VERSION 15.0(2)SE7 - High Hulc LED Process
STK1-MDF>sh proc cpu sort 5min
CPU utilization for five seconds: 38%/2%; one minute: 38%; five minutes: 37%
 PID Runtime(ms)     Invoked      uSecs   5Sec   1Min   5Min TTY Process
 180    82023681     9781932       8385 19.67% 18.98% 19.25%   0 Hulc LED Process
  90    18021827     3662711       4920  5.11%  4.78%  4.35%   0 RedEarth Tx Mana
  89     7298338     5322472       1371  2.07%  1.73%  1.71%   0 RedEarth I2C dri
   5     6989564      310469      22512  0.00%  1.74%  1.69%   0 Check heaps
 135     3327733      392590       8476  0.79%  0.74%  0.78%   0 hpm counter proc
 197     2178418      929110       2344  0.63%  0.45%  0.50%   0 HRPC qos request
 196     1385449       78162      17725  0.31%  0.31%  0.31%   0 HQM Stack Proces
 248     1144834     2567424        445  0.15%  0.23%  0.27%   0 Spanning Tree
 110         787         113       6964  0.31%  1.00%  0.23%   1 SSH Process
  11      924615        6529     141616  0.00%  0.32%  0.23%   0 Licensing Auto U
 136      946541     2452969        385  0.31%  0.20%  0.22%   0 HRPC pm-counters
STK1-MDF>sh proc cpu sort 1min
CPU utilization for five seconds: 35%/1%; one minute: 38%; five minutes: 37%
 180    82025176     9782110       8385 20.00% 19.06% 19.27%   0 Hulc LED Process
  90    18022158     3662771       4920  4.48%  4.76%  4.36%   0 RedEarth Tx Mana
  89     7298454     5322562       1371  1.59%  1.71%  1.71%   0 RedEarth I2C dri
   5     6989924      310485      22512  0.00%  1.60%  1.66%   0 Check heaps
 110         796         160       4975  0.31%  0.94%  0.24%   1 SSH Process
 135     3327792      392597       8476  0.79%  0.74%  0.78%   0 hpm counter proc
 197     2178477      929130       2344  0.63%  0.47%  0.50%   0 HRPC qos request
 196     1385483       78164      17725  0.31%  0.31%  0.31%   0 HQM Stack Proces
  11      924615        6529     141616  0.00%  0.29%  0.22%   0 Licensing Auto U
 248     1144860     2567471        445  0.15%  0.22%  0.27%   0 Spanning Tree
 136      946566     2453026        385  0.00%  0.19%  0.22%   0 HRPC pm-counters
STK1-MDF>sh proc cpu sort 5sec
CPU utilization for five seconds: 42%/1%; one minute: 38%; five minutes: 37%
 180    82026162     9782228       8385 19.83% 19.12% 19.28%   0 Hulc LED Process
   5     6989924      310485      22512  6.87%  2.02%  1.75%   0 Check heaps
  90    18022407     3662815       4920  4.63%  4.75%  4.36%   0 RedEarth Tx Mana
  89     7298556     5322628       1371  1.75%  1.72%  1.71%   0 RedEarth I2C dri
 135     3327833      392602       8476  0.79%  0.75%  0.78%   0 hpm counter proc
 197     2178494      929140       2344  0.63%  0.48%  0.51%   0 HRPC qos request
 136      946566     2453026        385  0.47%  0.21%  0.22%   0 HRPC pm-counters
 248     1144869     2567507        445  0.47%  0.24%  0.27%   0 Spanning Tree
 196     1385500       78165      17725  0.31%  0.31%  0.31%   0 HQM Stack Proces
 110         804         207       3884  0.15%  0.88%  0.23%   1 SSH Process
 266       87298      388930        224  0.15%  0.07%  0.01%   0 PI MATM Aging Pr
VERSION 15.0(2)SE5 - Bug Fixed
STK1-MDF>sho proc cpu sort 5min
CPU utilization for five seconds: 9%/0%; one minute: 11%; five minutes: 10%
   5      390218       18264      21365  0.00%  1.14%  1.18%   0 Check heaps
 169      394157      965241        408  1.27%  1.19%  1.17%   0 Hulc LED Process
 182      195799       74963       2611  0.63%  0.54%  0.56%   0 HRPC qos request
 108      178545        3149      56698  0.47%  0.48%  0.50%   0 HULC Tcam Memory
 181      107348        6340      16931  0.31%  0.31%  0.31%   0 HQM Stack Proces
 127       93240      206305        451  0.79%  0.32%  0.26%   0 HRPC pm-counters
 101       25640      181662        141  0.00%  0.33%  0.25%   0 HRPC hlfm reques
 137         804         118       6813  0.47%  1.00%  0.23%   1 SSH Process
 230       44694       87632        510  0.15%  0.21%  0.16%   0 CDP Protocol
  43       49284        4838      10186  0.31%  0.14%  0.14%   0 Net Background
 252       34375      182398        188  0.00%  0.08%  0.09%   0 Spanning Tree
STK1-MDF>sho proc cpu sort 1min
CPU utilization for five seconds: 16%/1%; one minute: 11%; five minutes: 11%
 169      394266      965490        408  1.27%  1.19%  1.17%   0 Hulc LED Process
   5      390260       18266      21365  0.79%  1.03%  1.15%   0 Check heaps
 137         854         196       4357  0.47%  0.95%  0.25%   1 SSH Process
 108      178712        3150      56733  3.20%  0.66%  0.54%   0 HULC Tcam Memory
 182      195866       74983       2612  0.79%  0.57%  0.56%   0 HRPC qos request
 101       25698      182194        141  0.79%  0.39%  0.27%   0 HRPC hlfm reques
 127       93274      206360        451  0.47%  0.32%  0.26%   0 HRPC pm-counters
 181      107382        6342      16931  0.31%  0.31%  0.31%   0 HQM Stack Proces
 230       44702       87657        509  0.00%  0.19%  0.15%   0 CDP Protocol
  43       49301        4840      10186  0.31%  0.14%  0.14%   0 Net Background
  88       26226     1645139         15  0.00%  0.08%  0.06%   0 Fifo Error Detec
STK1-MDF>sho proc cpu sort 5sec
CPU utilization for five seconds: 9%/1%; one minute: 11%; five minutes: 11%
 169      394332      965648        408  0.95%  1.17%  1.17%   0 Hulc LED Process
 181      107398        6343      16931  0.31%  0.31%  0.31%   0 HQM Stack Proces
  88       26243     1645425         15  0.31%  0.10%  0.07%   0 Fifo Error Detec
 137         871         243       3584  0.31%  0.90%  0.25%   1 SSH Process
 230       44710       87677        509  0.31%  0.20%  0.15%   0 CDP Protocol
 101       25707      182300        141  0.31%  0.39%  0.27%   0 HRPC hlfm reques
 182      195892       74995       2612  0.31%  0.55%  0.56%   0 HRPC qos request
  92       13064       78920        165  0.15%  0.05%  0.05%   0 hrpc <- response
  53       12665        6358       1991  0.15%  0.05%  0.03%   0 Compute load avg
  82        8269      571106         14  0.15%  0.04%  0.00%   0 RedEarth Tx Mana
 127       93298      206409        452  0.15%  0.30%  0.26%   0 HRPC pm-counters
