CSCso66911 - ASA55x0 GE output stuck and underrun errors
usman ali dar
we recently migrated to ASA and I found the that interface both inside and outside resets for 3 times and under run errors appears which makes issues with client server applications we are using can some one help we are using 9.1 version
usman ali dar
currently I am having some issues with my ASA ASA5545 WITH 9.1.1 Version.
it started with a application issue that stops in middle of the operations and then no body can log into the application server and after sometime it start working again and then stops again after some time.
I figure out the switch it was connected was generating a lot errors on trunk so I moved the connections to powerfull nexus switch.
I am currently seeing this errors and unable to understand them completely I am requiring you help please
Interface GigabitEthernet0/0 "inside", is up, line protocol is up
  Hardware is i82574L rev00, BW 1000 Mbps, DLY 10 usec
        Auto-Duplex(Full-duplex), Auto-Speed(1000 Mbps)
        Input flow control is unsupported, output flow control is off
        MAC address 0.0.0.0.0.0.0, MTU 1500
        IP address 192.168.1.1, subnet mask 255.255.255.0
        4427403602 packets input, 2151227118434 bytes, 0 no buffer
        Received 42396148 broadcasts, 0 runts, 0 giants
        0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
        0 pause input, 0 resume input
        0 L2 decode drops
        5719508097 packets output, 5277823402324 bytes, 237 underruns
        0 pause output, 0 resume output
        0 output errors, 0 collisions, 4 interface resets
        0 late collisions, 0 deferred
        0 input reset drops, 0 output reset drops
        input queue (blocks free curr/low): hardware (477/388)
        output queue (blocks free curr/low): hardware (479/71)
  Traffic Statistics for "inside":
        3893211898 packets input, 1264275976406 bytes
        5719508357 packets output, 5171974072466 bytes
        43272956 packets dropped
      1 minute input rate 5528 pkts/sec,  685081 bytes/sec
      1 minute output rate 14596 pkts/sec,  18382094 bytes/sec
      1 minute drop rate, 23 pkts/sec
      5 minute input rate 6259 pkts/sec,  799966 bytes/sec
      5 minute output rate 14373 pkts/sec,  17747799 bytes/sec
      5 minute drop rate, 24 pkts/sec
Interface GigabitEthernet0/7 "outside", is up, line protocol is up
        MAC address aaaaaaaaaaaaaaa, MTU 1500
        IP address 192.1.1.1, subnet mask 255.255.255.0
        36328017115 packets input, 18021883345657 bytes, 0 no buffer
        Received 164971366 broadcasts, 0 runts, 0 giants
        31781 input errors, 0 CRC, 0 frame, 31781 overrun, 0 ignored, 0 abort
        0 L2 decode drops
        39369900910 packets output, 29835988021321 bytes, 0 underruns
        0 input reset drops, 79 output reset drops
        input queue (blocks free curr/low): hardware (476/366)
        output queue (blocks free curr/low): hardware (456/378)
  Traffic Statistics for "outside":
        36327768794 packets input, 17325171050057 bytes
        39369901040 packets output, 29101930308442 bytes
        346411335 packets dropped
      1 minute input rate 22754 pkts/sec,  29334277 bytes/sec
      1 minute output rate 7454 pkts/sec,  1110781 bytes/sec
      1 minute drop rate, 46 pkts/sec
      5 minute input rate 16126 pkts/sec,  20051269 bytes/sec
      5 minute output rate 6501 pkts/sec,  1045907 bytes/sec
      5 minute drop rate, 46 pkts/sec
- See more at: https://supportforums.cisco.com/discussion/11094501/help-underrun-between-asa5540-%E2%80%93-asa-ssm-20#comment-10516936
