CSCtg00438 - Need a way to syslog per-class COPP drops based on thresholds
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
07-30-2012 03:50 AM - edited 03-20-2019 07:58 PM
I know that the bug is fixed, but when I´m trying to configure the CoPP-Logging stuff under NX-OS 5.2(5) I do not see any kind of logs even if the policy is already dropping the traffic.
Config is:
policy-map type control-plane copp-system-policy
class copp-system-class-exception
logging drop threshold 39600000 level 5
regards,
Dirk
- Labels:
Cisco Bugs
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
07-30-2012 10:09 AM
The bug id you mention added the CLI, so if the CLI is accepted you already have the patch. However, there may be some other issue, whether it is a new bug of a configuration error in logging. It would be best to ask the question in another forum (or oprn a TAC case), since this is either a configuration issue or a new bug.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-06-2012 11:25 PM
it seems that since 5.2.x, the default-policies are "read-only" so you have to copy the policy and then add the logging-stuff.
Will try it and provide some feedback.
regards,
Dirk
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
08-16-2012 08:32 AM
After copying to policy and modifying it everything works as expected!
