CSCto07667issue with two of his 2x3750 stacks- unable to do write mem
Asim Afzal
Hi Team,
Getting below error while saving the configuration
Unable to save the configuration due to error '' Unable to open flash config.txt.new''
I can see below below bug detail but i can;t see details
Below is show ver
Cisco IOS Software, C3750E Software (C3750E-UNIVERSALK9-M), Version 15.0(2)SE8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Wed 13-May-15 22:53 by prod_rel_team
ROM: Bootstrap program is C3750E boot loader
BOOTLDR: C3750E Boot Loader (C3750X-HBOOT-M) Version 12.2(53r)SE2, RELEASE SOFTWARE (fc1)
AUH-ICHQ-SER-13Flr-SW uptime is 21 weeks, 3 days, 7 hours, 5 minutes
System restarted at 15:32:32 GMT Fri Aug 31 2018
System image file is "flash:c3750e-universalk9-mz.150-2.SE8.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: lanbase
License Type: Permanent
Next reload license Level: lanbase
cisco WS-C3750X-48P (PowerPC405) processor (revision A0) with 262144K bytes of memory.
Processor board ID
Last reset from power-on
2 Virtual Ethernet interfaces
1 FastEthernet interface
132 Gigabit Ethernet interfaces
6 Ten Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
Leo Laohoo
That's not a bug.  This means that flash already contains a file called "config.txt.new".
we are saving with command  wr mem and getting that error.
So what needs to be done
1. Post the complete output to the command "sh boot";
2. Try the command "copy run start"
