CSCuc40354%20-%20B200%200424%20CMOS%20Battery%20Voltage%20Lower-critical
There is any command line to check the battery charge?
Thank You,
jairochavez
Check for certain that their battery has sufficient charge, here are the steps.
-Capture 'Show tech Chaasis X' where X is the chassis containing the affected blade.
-Unzip and open Tech Support
-In the Tech Support, find, unzip and open the file CIMCX.techsupport where X is the affected blade
-In that file expand the folder "tmp"
-Open the file CIMCX.techsupport.txt
-In that file you will do a search for the value - P3V_BAT_SCALED
The value of a charge battery should be greater than 2.0. If the value is lower then 2.0, then the battery needs to be replaced.
624801-B# connect cimc 2/4
Trying 127.6.2.4...
Connected to 127.6.2.4.
Escape character is '^]'.
CIMC Debug Firmware Utility Shell [ support ]
[ help ]# sensors
Sensor Name | Reading | Unit | Status | LNR | LC | LNC | UNC | UC | UNR |
P3V_BAT_SCALED | 2.231 | Volts | LC | 1.993 | 2.416 | na | na | 3.287 | na |
