CSCug79472 - Voltage alerts going Upper and lower Critical C460 M2
ash_thomas
ESXi host is showing a hardware voltage alarm.
In the UCSManger , SEL log is filled with the following logs:
701 | 04/24/2018 01:28:59 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
702 | 04/24/2018 01:30:59 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
703 | 04/24/2018 01:31:03 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
704 | 04/24/2018 01:33:12 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
705 | 04/24/2018 01:33:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
706 | 04/24/2018 01:33:30 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
707 | 04/24/2018 01:33:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
708 | 04/24/2018 01:33:43 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
709 | 04/24/2018 01:33:45 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
70a | 04/24/2018 01:34:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
70b | 04/24/2018 01:34:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
70c | 04/24/2018 01:34:27 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
70d | 04/24/2018 01:34:31 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
70e | 04/24/2018 01:35:57 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
70f | 04/24/2018 01:35:59 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
710 | 04/24/2018 01:36:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
711 | 04/24/2018 01:36:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
712 | 04/24/2018 01:36:58 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
713 | 04/24/2018 01:37:02 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
714 | 04/24/2018 01:39:00 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
715 | 04/24/2018 01:39:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
716 | 04/24/2018 01:40:31 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
717 | 04/24/2018 01:40:33 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
718 | 04/24/2018 01:40:45 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
719 | 04/24/2018 01:40:50 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
71a | 04/24/2018 01:41:42 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
71b | 04/24/2018 01:41:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
71c | 04/24/2018 01:41:51 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
71d | 04/24/2018 01:41:53 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
71e | 04/24/2018 01:42:31 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
71f | 04/24/2018 01:42:33 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
720 | 04/24/2018 01:42:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
721 | 04/24/2018 01:42:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
722 | 04/24/2018 01:44:58 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
723 | 04/24/2018 01:45:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
724 | 04/24/2018 01:45:31 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
725 | 04/24/2018 01:45:35 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
726 | 04/24/2018 01:47:31 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
727 | 04/24/2018 01:47:37 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
728 | 04/24/2018 01:47:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
729 | 04/24/2018 01:48:07 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
72a | 04/24/2018 01:49:23 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
72b | 04/24/2018 01:49:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
72c | 04/24/2018 01:49:47 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
72d | 04/24/2018 01:49:48 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
72e | 04/24/2018 01:51:08 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
72f | 04/24/2018 01:51:12 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
730 | 04/24/2018 01:51:27 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
731 | 04/24/2018 01:51:29 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
732 | 04/24/2018 01:52:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
733 | 04/24/2018 01:52:47 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
734 | 04/24/2018 01:53:27 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
735 | 04/24/2018 01:53:29 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
736 | 04/24/2018 01:53:56 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
737 | 04/24/2018 01:54:00 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
738 | 04/24/2018 01:54:05 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
739 | 04/24/2018 01:54:19 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
73a | 04/24/2018 01:54:23 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
73b | 04/24/2018 01:54:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
73c | 04/24/2018 01:56:00 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
73d | 04/24/2018 01:56:02 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
73e | 04/24/2018 02:01:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
73f | 04/24/2018 02:01:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
740 | 04/24/2018 02:02:18 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
741 | 04/24/2018 02:02:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
742 | 04/24/2018 02:04:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
743 | 04/24/2018 02:04:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
744 | 04/24/2018 02:10:55 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
745 | 04/24/2018 02:10:57 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
746 | 04/24/2018 02:11:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
747 | 04/24/2018 02:11:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
748 | 04/24/2018 02:13:38 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
749 | 04/24/2018 02:13:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
74a | 04/24/2018 02:18:08 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
74b | 04/24/2018 02:18:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
74c | 04/24/2018 02:18:48 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
74d | 04/24/2018 02:18:55 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
74e | 04/24/2018 02:19:40 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
74f | 04/24/2018 02:19:47 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
750 | 04/24/2018 02:19:54 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
751 | 04/24/2018 02:19:56 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
752 | 04/24/2018 02:19:58 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
753 | 04/24/2018 02:20:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
754 | 04/24/2018 02:23:42 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
755 | 04/24/2018 02:23:49 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
756 | 04/24/2018 02:23:55 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
757 | 04/24/2018 02:23:57 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
758 | 04/24/2018 02:24:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
759 | 04/24/2018 02:24:34 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
75a | 04/24/2018 02:25:00 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
75b | 04/24/2018 02:25:02 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
75c | 04/24/2018 02:25:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
75d | 04/24/2018 02:25:55 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
75e | 04/24/2018 02:26:07 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
75f | 04/24/2018 02:26:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
760 | 04/24/2018 02:29:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
761 | 04/24/2018 02:29:29 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
762 | 04/24/2018 02:30:09 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
763 | 04/24/2018 02:30:13 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
764 | 04/24/2018 02:30:28 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
765 | 04/24/2018 02:30:30 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
766 | 04/24/2018 02:31:00 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
767 | 04/24/2018 02:31:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
768 | 04/24/2018 02:32:24 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
769 | 04/24/2018 02:32:34 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
76a | 04/24/2018 02:32:53 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
76b | 04/24/2018 02:32:55 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
76c | 04/24/2018 02:34:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
76d | 04/24/2018 02:34:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
76e | 04/24/2018 02:34:49 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
76f | 04/24/2018 02:34:52 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
770 | 04/24/2018 02:36:38 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
771 | 04/24/2018 02:36:40 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
772 | 04/24/2018 02:38:21 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
773 | 04/24/2018 02:38:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
774 | 04/24/2018 02:38:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
775 | 04/24/2018 02:38:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
776 | 04/24/2018 02:38:59 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
777 | 04/24/2018 02:39:01 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
778 | 04/24/2018 02:39:12 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
779 | 04/24/2018 02:39:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
77a | 04/24/2018 02:39:49 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
77b | 04/24/2018 02:39:51 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
77c | 04/24/2018 02:41:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
77d | 04/24/2018 02:41:18 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
77e | 04/24/2018 02:41:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
77f | 04/24/2018 02:41:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
780 | 04/24/2018 02:44:59 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
781 | 04/24/2018 02:45:03 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
782 | 04/24/2018 02:46:12 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
783 | 04/24/2018 02:46:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
784 | 04/24/2018 02:48:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
785 | 04/24/2018 02:48:43 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
786 | 04/24/2018 02:50:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
787 | 04/24/2018 02:50:18 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
788 | 04/24/2018 02:50:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
789 | 04/24/2018 02:50:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
78a | 04/24/2018 02:51:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
78b | 04/24/2018 02:51:07 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
78c | 04/24/2018 02:51:49 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
78d | 04/24/2018 02:51:51 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
78e | 04/24/2018 02:53:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
78f | 04/24/2018 02:53:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
790 | 04/24/2018 02:54:12 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
791 | 04/24/2018 02:54:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
792 | 04/24/2018 02:55:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
793 | 04/24/2018 02:55:18 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
794 | 04/24/2018 02:57:26 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
795 | 04/24/2018 02:57:30 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
796 | 04/24/2018 03:02:57 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
797 | 04/24/2018 03:03:05 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
798 | 04/24/2018 03:09:12 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
799 | 04/24/2018 03:09:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
79a | 04/24/2018 03:10:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
79b | 04/24/2018 03:10:19 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
79c | 04/24/2018 03:11:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
79d | 04/24/2018 03:11:43 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
79e | 04/24/2018 03:13:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
79f | 04/24/2018 03:13:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7a0 | 04/24/2018 03:13:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7a1 | 04/24/2018 03:13:34 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7a2 | 04/24/2018 03:15:48 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7a3 | 04/24/2018 03:15:53 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7a4 | 04/24/2018 03:17:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7a5 | 04/24/2018 03:17:18 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7a6 | 04/24/2018 03:30:08 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7a7 | 04/24/2018 03:30:10 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7a8 | 04/24/2018 03:34:38 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7a9 | 04/24/2018 03:34:40 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7aa | 04/24/2018 03:40:21 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7ab | 04/24/2018 03:40:23 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7ac | 04/24/2018 03:46:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7ad | 04/24/2018 03:46:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7ae | 04/24/2018 03:51:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7af | 04/24/2018 03:51:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7b0 | 04/24/2018 03:58:02 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7b1 | 04/24/2018 03:58:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7b2 | 04/24/2018 04:15:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7b3 | 04/24/2018 04:15:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7b4 | 04/24/2018 04:22:59 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7b5 | 04/24/2018 04:23:03 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7b6 | 04/24/2018 04:27:55 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7b7 | 04/24/2018 04:27:59 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7b8 | 04/24/2018 04:30:42 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7b9 | 04/24/2018 04:30:45 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7ba | 04/24/2018 04:33:09 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7bb | 04/24/2018 04:33:13 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7bc | 04/24/2018 04:44:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7bd | 04/24/2018 04:44:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7be | 04/24/2018 04:47:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7bf | 04/24/2018 04:47:43 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7c0 | 04/24/2018 04:50:03 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7c1 | 04/24/2018 04:50:05 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7c2 | 04/24/2018 04:55:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7c3 | 04/24/2018 04:55:08 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7c4 | 04/24/2018 04:56:07 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7c5 | 04/24/2018 04:56:09 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7c6 | 04/24/2018 04:58:24 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7c7 | 04/24/2018 04:58:26 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7c8 | 04/24/2018 04:59:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7c9 | 04/24/2018 04:59:08 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7ca | 04/24/2018 05:00:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7cb | 04/24/2018 05:00:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7cc | 04/24/2018 05:02:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7cd | 04/24/2018 05:02:43 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7ce | 04/24/2018 05:05:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7cf | 04/24/2018 05:05:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7d0 | 04/24/2018 05:21:30 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7d1 | 04/24/2018 05:21:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7d2 | 04/24/2018 05:42:02 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7d3 | 04/24/2018 05:42:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7d4 | 04/24/2018 05:42:07 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7d5 | 04/24/2018 05:42:13 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7d6 | 04/24/2018 05:43:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7d7 | 04/24/2018 05:43:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7d8 | 04/24/2018 05:49:36 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7d9 | 04/24/2018 05:49:38 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7da | 04/24/2018 05:51:03 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7db | 04/24/2018 05:51:05 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7dc | 04/24/2018 05:52:36 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7dd | 04/24/2018 05:52:42 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7de | 04/24/2018 05:54:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7df | 04/24/2018 05:54:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7e0 | 04/24/2018 06:01:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7e1 | 04/24/2018 06:01:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7e2 | 04/24/2018 06:01:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7e3 | 04/24/2018 06:01:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7e4 | 04/24/2018 06:02:47 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7e5 | 04/24/2018 06:02:49 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7e6 | 04/24/2018 06:12:47 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7e7 | 04/24/2018 06:12:56 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7e8 | 04/24/2018 06:14:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7e9 | 04/24/2018 06:14:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7ea | 04/24/2018 06:14:24 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7eb | 04/24/2018 06:14:28 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7ec | 04/24/2018 06:16:01 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7ed | 04/24/2018 06:16:05 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7ee | 04/24/2018 06:16:59 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7ef | 04/24/2018 06:17:02 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7f0 | 04/24/2018 06:17:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7f1 | 04/24/2018 06:17:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7f2 | 04/24/2018 06:20:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7f3 | 04/24/2018 06:20:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7f4 | 04/24/2018 06:22:07 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7f5 | 04/24/2018 06:22:09 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7f6 | 04/24/2018 06:24:51 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7f7 | 04/24/2018 06:24:53 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7f8 | 04/24/2018 06:27:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7f9 | 04/24/2018 06:27:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7fa | 04/24/2018 06:30:23 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7fb | 04/24/2018 06:30:29 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7fc | 04/24/2018 06:34:23 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7fd | 04/24/2018 06:34:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
7fe | 04/24/2018 06:36:57 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
7ff | 04/24/2018 06:36:59 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
800 | 04/24/2018 06:37:01 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
801 | 04/24/2018 06:37:03 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
802 | 04/24/2018 06:38:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
803 | 04/24/2018 06:38:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
804 | 04/24/2018 06:40:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
805 | 04/24/2018 06:40:13 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
806 | 04/24/2018 06:40:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
807 | 04/24/2018 06:40:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
808 | 04/24/2018 06:41:19 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
809 | 04/24/2018 06:41:21 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
80a | 04/24/2018 06:43:52 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
80b | 04/24/2018 06:43:54 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
80c | 04/24/2018 06:46:37 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
80d | 04/24/2018 06:46:43 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
80e | 04/24/2018 06:49:26 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
80f | 04/24/2018 06:49:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
810 | 04/24/2018 06:49:36 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
811 | 04/24/2018 06:49:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
812 | 04/24/2018 06:50:40 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
813 | 04/24/2018 06:50:42 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
814 | 04/24/2018 06:52:31 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
815 | 04/24/2018 06:52:33 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
816 | 04/24/2018 06:54:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
817 | 04/24/2018 06:54:21 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
818 | 04/24/2018 06:57:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
819 | 04/24/2018 06:57:52 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
81a | 04/24/2018 07:00:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
81b | 04/24/2018 07:00:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
81c | 04/24/2018 07:01:28 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
81d | 04/24/2018 07:01:34 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
81e | 04/24/2018 07:03:51 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
81f | 04/24/2018 07:03:53 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
820 | 04/24/2018 07:07:21 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
821 | 04/24/2018 07:07:23 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
822 | 04/24/2018 07:09:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
823 | 04/24/2018 07:09:08 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
824 | 04/24/2018 07:10:28 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
825 | 04/24/2018 07:10:30 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
826 | 04/24/2018 07:10:36 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
827 | 04/24/2018 07:10:38 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
828 | 04/24/2018 07:11:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
829 | 04/24/2018 07:11:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
82a | 04/24/2018 07:12:34 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
82b | 04/24/2018 07:12:36 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
82c | 04/24/2018 07:12:51 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
82d | 04/24/2018 07:12:53 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
82e | 04/24/2018 07:13:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
82f | 04/24/2018 07:13:18 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
830 | 04/24/2018 07:15:31 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
831 | 04/24/2018 07:15:33 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
832 | 04/24/2018 07:16:26 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
833 | 04/24/2018 07:16:28 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
834 | 04/24/2018 07:17:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
835 | 04/24/2018 07:17:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
836 | 04/24/2018 07:17:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
837 | 04/24/2018 07:17:36 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
838 | 04/24/2018 07:24:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
839 | 04/24/2018 07:24:30 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
83a | 04/24/2018 07:27:05 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
83b | 04/24/2018 07:27:08 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
83c | 04/24/2018 07:28:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
83d | 04/24/2018 07:28:48 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
83e | 04/24/2018 07:35:54 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
83f | 04/24/2018 07:35:58 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
840 | 04/24/2018 07:39:08 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
841 | 04/24/2018 07:39:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
842 | 04/24/2018 07:39:40 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
843 | 04/24/2018 07:39:42 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
844 | 04/24/2018 07:45:10 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
845 | 04/24/2018 07:45:12 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
846 | 04/24/2018 07:46:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
847 | 04/24/2018 07:46:19 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
848 | 04/24/2018 07:46:40 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
849 | 04/24/2018 07:46:42 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
84a | 04/24/2018 07:49:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
84b | 04/24/2018 07:49:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
84c | 04/24/2018 07:52:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
84d | 04/24/2018 07:52:13 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
84e | 04/24/2018 07:52:38 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
84f | 04/24/2018 07:52:52 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
850 | 04/24/2018 07:53:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
851 | 04/24/2018 07:53:24 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
852 | 04/24/2018 07:53:58 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
853 | 04/24/2018 07:54:00 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
854 | 04/24/2018 07:56:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
855 | 04/24/2018 07:56:36 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
856 | 04/24/2018 08:00:03 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
857 | 04/24/2018 08:00:07 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
858 | 04/24/2018 08:03:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
859 | 04/24/2018 08:03:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
85a | 04/24/2018 08:04:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
85b | 04/24/2018 08:04:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
85c | 04/24/2018 08:05:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
85d | 04/24/2018 08:05:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
85e | 04/24/2018 08:06:40 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
85f | 04/24/2018 08:06:47 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
860 | 04/24/2018 08:09:45 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
861 | 04/24/2018 08:09:49 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
862 | 04/24/2018 08:22:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
863 | 04/24/2018 08:22:49 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
864 | 04/24/2018 08:24:55 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
865 | 04/24/2018 08:25:03 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
866 | 04/24/2018 08:26:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
867 | 04/24/2018 08:26:27 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
868 | 04/24/2018 08:27:18 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
869 | 04/24/2018 08:27:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
86a | 04/24/2018 08:27:47 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
86b | 04/24/2018 08:27:48 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
86c | 04/24/2018 08:40:48 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
86d | 04/24/2018 08:40:49 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
86e | 04/24/2018 08:48:19 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
86f | 04/24/2018 08:48:21 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
870 | 04/24/2018 08:49:54 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
871 | 04/24/2018 08:49:56 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
872 | 04/24/2018 08:50:36 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
873 | 04/24/2018 08:50:38 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
874 | 04/24/2018 08:55:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
875 | 04/24/2018 08:55:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
876 | 04/24/2018 09:07:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
877 | 04/24/2018 09:07:31 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
878 | 04/24/2018 09:19:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
879 | 04/24/2018 09:19:43 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
87a | 04/24/2018 09:19:47 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
87b | 04/24/2018 09:19:56 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
87c | 04/24/2018 09:23:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
87d | 04/24/2018 09:23:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
87e | 04/24/2018 09:27:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
87f | 04/24/2018 09:27:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
880 | 04/24/2018 09:29:45 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
881 | 04/24/2018 09:29:47 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
882 | 04/24/2018 09:42:19 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
883 | 04/24/2018 09:42:21 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
884 | 04/24/2018 09:46:38 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
885 | 04/24/2018 09:46:50 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
886 | 04/24/2018 09:50:09 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
887 | 04/24/2018 09:50:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
888 | 04/24/2018 09:52:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
889 | 04/24/2018 09:52:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
88a | 04/24/2018 09:56:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
88b | 04/24/2018 09:56:36 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
88c | 04/24/2018 09:58:01 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
88d | 04/24/2018 09:58:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
88e | 04/24/2018 10:09:49 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
88f | 04/24/2018 10:09:55 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
890 | 04/24/2018 10:19:45 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
891 | 04/24/2018 10:19:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
892 | 04/24/2018 10:20:55 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
893 | 04/24/2018 10:20:57 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
894 | 04/24/2018 10:36:37 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
895 | 04/24/2018 10:36:39 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
896 | 04/24/2018 10:43:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
897 | 04/24/2018 10:43:24 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
898 | 04/24/2018 10:46:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
899 | 04/24/2018 10:46:25 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
89a | 04/24/2018 10:54:07 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
89b | 04/24/2018 10:54:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
89c | 04/24/2018 11:10:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
89d | 04/24/2018 11:10:19 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
89e | 04/24/2018 11:13:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
89f | 04/24/2018 11:13:21 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8a0 | 04/24/2018 11:17:35 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8a1 | 04/24/2018 11:17:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8a2 | 04/24/2018 11:18:48 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8a3 | 04/24/2018 11:18:50 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8a4 | 04/24/2018 11:23:28 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8a5 | 04/24/2018 11:23:30 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8a6 | 04/24/2018 11:23:45 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8a7 | 04/24/2018 11:23:50 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8a8 | 04/24/2018 11:25:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8a9 | 04/24/2018 11:25:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8aa | 04/24/2018 11:28:38 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8ab | 04/24/2018 11:28:40 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8ac | 04/24/2018 11:31:04 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8ad | 04/24/2018 11:31:06 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8ae | 04/24/2018 11:32:18 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8af | 04/24/2018 11:32:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8b0 | 04/24/2018 11:33:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8b1 | 04/24/2018 11:33:20 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8b2 | 04/24/2018 11:36:17 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8b3 | 04/24/2018 11:36:19 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8b4 | 04/24/2018 11:38:40 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8b5 | 04/24/2018 11:38:45 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8b6 | 04/24/2018 11:39:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8b7 | 04/24/2018 11:39:16 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8b8 | 04/24/2018 11:40:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8b9 | 04/24/2018 11:40:24 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8ba | 04/24/2018 11:44:33 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8bb | 04/24/2018 11:44:35 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8bc | 04/24/2018 11:46:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8bd | 04/24/2018 11:46:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8be | 04/24/2018 11:47:41 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8bf | 04/24/2018 11:47:45 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8c0 | 04/24/2018 11:49:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8c1 | 04/24/2018 11:49:13 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8c2 | 04/24/2018 11:51:09 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8c3 | 04/24/2018 11:51:10 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8c4 | 04/24/2018 11:52:42 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8c5 | 04/24/2018 11:52:44 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8c6 | 04/24/2018 11:53:46 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8c7 | 04/24/2018 11:53:50 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8c8 | 04/24/2018 11:54:22 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8c9 | 04/24/2018 11:54:26 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8ca | 04/24/2018 11:56:32 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8cb | 04/24/2018 11:56:34 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8cc | 04/24/2018 12:00:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8cd | 04/24/2018 12:00:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8ce | 04/24/2018 12:05:29 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8cf | 04/24/2018 12:05:31 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8d0 | 04/24/2018 12:09:14 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8d1 | 04/24/2018 12:09:15 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8d2 | 04/24/2018 12:09:27 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8d3 | 04/24/2018 12:09:33 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8d4 | 04/24/2018 12:10:09 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8d5 | 04/24/2018 12:10:11 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8d6 | 04/24/2018 23:47:27 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8d7 | 04/24/2018 23:47:30 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8d8 | 04/25/2018 01:13:19 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8d9 | 04/25/2018 01:13:21 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
8da | 04/25/2018 01:21:18 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Deasserted | Reading 2.43 >= Threshold 2.40 Volts
8db | 04/25/2018 01:21:29 | CIMC | Voltage P3V_BAT_SCALED #0x00 | Lower Non-critical - going low | Asserted | Reading 2.40 <= Threshold 2.40 Volts
Please suggest , how to solve this. Whats the root cause of this
0 Replies 0
