CSCuq27367 - IPP TMM refCntMemErr errors when enabling ip pim on 4500 switches
Ale1985
In addition to "Workaround: Reduce the number of interfaces receiving replicated packets", there are other solutions for this BUG?
Because I just encountered the problem on the switch 4503-E with release IOS XE 3.8.7E and ROMMON IOS 15.0(1r)SG10.
On this document https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst4500/12-2/52sg/system/messages/sysmess/emsg.html#wp1981495 the recommended action: if this message is a fatal error contact Cisco TAC, otherwise no further actions are necessary.
The counters of this command "show platform hardware interrupts" refers to the number of interfaces enabled for multicast PIM or to single packets?
Alessandro
0 Replies 0
