CSCuu02970 - CSCuq19142 workaround doesnand39;t work on very old 4400s with Airespace MIC
Not applicable
I need to upgrade a AIR-WLC4404-100-K9 to 7.0(252.51) version to fix the CSCuu02970 bug.
The last available release that I see in Cisco page is 7.0.252.0.
Could someone tell me if  7.0(252.51  version is available and where I can download it?
Thanks in advance.
Regards.
Inhancedigi
Any updates on this?  I need 252.51
Same here please.
Our EOS WLC4400's running 7.0(252.0) have the manufacturer installed cert issue identified in CSCuu02970.  Is there a 7.0(252.51) fixed release available to download for the WLC4400 like there is for the WLC5500 please?
Sam
We needed to open a TAC case to receive the 7.0(252.51) version of code.  You won't find it on Cisco's web site as of 3/16/2016.
I have the same problem, but from the TAC did not give me support or access to the new version of software because the product has entered End-of-Support-Date 30-Jun-2016, how you could get version 7.0.252.51?
Thank you
