CSCuv68628 - ISE 1.3P2 hangs while issue Show Run and stuck to generate support-bundle. - 1
kolateru1
Is 1.4.0.253 patch 10 affected by this bug as well?
kevink707
I just ran into this issue with ISE 2.4 patch 9.
If you reload the box it goes back to factory default settings (because no saved config is found).
The work-around is to open a TAC case and the TAC will use their root shell to fix some symlinks.
maheshvisave
Just fixed the issue with disabling CDP on ISE VM version 2.6 patch 3.
Please add under "known affected release: " tab.
Cisco Identity Services Engine
Version : 2.6.0.156
Thanks and regards,
Mahesh Visave
