CSCva97702 - C3650 QoS Class-map, DSCP counters issue
roward
I've seen this Bug on the V3.6.3E version of the code on a c3850.
Does any one know if there is an outlook for resolution?
There are no fixed releases listed in the bug description.
Kr, Rob.
ben.reynolds
I have this problem too and it's driving me up the wall tbh. We occassionally get some quality issues and I'm shooting the dark a little without the stats.
... Hi I've heard that 16.8.1 code might be fixed on some platforms, but I've not had the opportunity to test.... and its not mentioned in the bug search so I'm not that hopeful.
roward
The problem is also seen on Cat 9300 running 16.9.2
Switch Ports Model SW Version SW Image Mode
* 1 40 C9300-24UX 16.9.2 CAT9K_IOSXE INSTALL
sh policy-map interface te1/0/2
TenGigabitEthernet1/0/2
Service-policy output: TEST
Class-map: test (match-any)
0 packets                   <---------!
Match: dscp cs6 (48)
Queueing
(total drops) 0
(bytes output) 42232443
bandwidth 30% (3000000 kbps)
Class-map: class-default (match-any)
Match: any
Queueing
(total drops) 0
(bytes output) 584280
bandwidth 50% (5000000 kbps)
Note the above policy was created to test this bug on the platform and for no other purpose.
