09-04-2017 06:35 AM - edited 03-20-2019 09:30 PM
Does anyone know the work around for this?
I can install any V7.x.x image and the AP works fine, install any 8.x.x image and the AP goes into the boot loop failing on the Radio FW Image download.
Tried updating the image via Rmon, is there a version I need to install to get this AP working with V8.2.151
12-18-2017 01:03 PM
(pppsssttt .. dont tell anyone. But aparently TAC has a script that will help you ID the affected APs)
(and still dont tell anyone - 8.5MR1 and the upcomming 8.3MR4 fixes this problem - aka it is not a hardware problem).
12-18-2017 01:06 PM - edited 12-18-2017 01:07 PM
LOL. Thanks for the tip, Thomas.
12-18-2017 01:11 PM
It does not, according to the little birdie who told me, it will ID the APs for you.
There is also another way to ID affected APs, predownload new software.
If APs fail predownloading they are affected.
Im not 100% on the workaround (other then format flash), but I think someone mentioned (maybe it was a a Squirrel near by) that resetting the AP to factory defaults from the WLC might do the trick.
But the newly release 8.5MR1 should fix this flash problem (along with a couple of others) the same goes for upcoming 8.3MR4 (due out before Christmas --- Santa promised that).
12-18-2017 01:40 PM - edited 12-18-2017 01:41 PM
So forcing to perform a factory-reset by using the controller won't fix the issue because the AP won't accept any commands.
I am currently running 8.5MR1 and I'm observing the situation.
Well, TAC needs to do more work. What about the scenario when the CAPWAP IOS is corrupt and the AP goes "dumb" and won't load the next IOS from the directory.
Another thing, this bug affects only the 2700/3700. It is most likely the reason why this is happening is because Cisco is playing around "renaming" the IOS files from ap3g2 to c3700.
What is the intention for this exercise? Oh, I don't know. Maybe to make sure the 2600/3600 doesn't get supported on 8.6 even though the 2600/3600 can support the features in 8.6. Maybe.
NOTE: In the Release Notes in 8.6, it is stated that the 2600/3600 won't be supported. However, I have managed to get a 3600 loaded with an 8.6.101.0 firmware.
12-18-2017 01:46 PM
Yes you are right all the "fixes" only helps pre problem encounter (or whatever we should call it). If an AP has already gone "bad" theres only physical hands on recovery :-/
Hmmm .. Im sure it should have been fixed in 8.5MR1 .. ow well . bugger :-/
PS: this issue should also affect 2600 / 3600 not just 1700/2700/3700 . something about these APs using flash in the same way , or having the same kind of flash or flash controller .. something along those lines.
12-18-2017 02:30 PM
12-18-2017 02:33 PM
Well there are a couple of bugs regarding flash that affects these APs this is one of them ... unfortunately there are more.
It seems to be about how many events that happens on the AP (DFS, CAPWAP, unstable lines resulting in CAPWAP flapping and so on). from it being switched on, to rebooting (for whatever reason).
01-01-2018 05:07 AM
Such events cause read/write activity with the flashcard (event.log, capwap-saved-config etc.), it is a wild guess but maybe after some time or x amount of actions the allocation of space on the flashcard goes wrong or some kind of index is lost?
Based on S1 bug CSCvf16302 it does indeed not seem to be a hardware issue. Has anyone seen these kind of issues in deployments which are running older versions of code (<8.0.131)?
01-01-2018 12:19 PM
This issue only appears when loaded with 8.X (and later) and only predominantly affects 2700/3700. I have never seen these (plural) issues appear on 3500, 2600/3600.
02-22-2018 01:31 PM - edited 06-04-2018 11:42 PM
I found that based on the output of the commands below it can be established if a operational access-point is having communication issues with the internal flashcard. Combine this with your favorite programming language and you can perform proactive "access-point health checks".
The good news is that bug CSCvf16302 (and others related to flash problems) will be fixed in 8.2 MR7, based on the release notes related to the recently posted interim version.
AP#show file systems
File Systems:
Size(b) Free(b) Type Flags Prefixes
* - - flash rw flash:
AP#show logg
*Feb 18 13:22:42.603: %LWAPP-3-CLIENTERRORLOG: Save LWAPP Config: error saving config file
AP#fsck flash:
Fsck operation may take a while. Continue? [confirm]
%Error fscking flash: (Device or resource busy)
Please rate useful posts... :-)
Update: Cisco published a document regarding the flash problems covering multiple bugs.
03-05-2019 04:16 AM - edited 03-05-2019 04:29 AM
Got a 2600 on my desk that's doing it. Wiped the flash and TFTP'd a recovery image onto it, all OK. Joined back to the LAN, let the controller reflash it to ap3g2-k9w8-mx.153-3.JD16 (controller is running 8.3.143.0) and the problem comes straight back again.
IOS Bootloader - Starting system.
flash is writable
FLASH CHIP: Numonyx Mirrorbit (0089)
Xmodem file system is available.
flashfs[0]: 61 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 31997952
flashfs[0]: Bytes used: 15283712
flashfs[0]: Bytes available: 16714240
flashfs[0]: flashfs fsck took 16 seconds.
Reading cookie from SEEPROM
Base Ethernet MAC address: 7c:69:f6:bc:6c:58
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.153-3.JD16/ap3g2-k9w8-mx.153-3.JD16"...#########################
File "flash:/ap3g2-k9w8-mx.153-3.JD16/ap3g2-k9w8-mx.153-3.JD16" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Tide MB - 32MB of flash
flashfs[0]: flashfs fsck took 8 seconds.
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 1 seconds.
2600/3600 AP, PID: 'AIR-CAP2602I-E-K9 '. Checking for BL upgrade...
BL: C2600 Boot Loader (AP3G2-BOOT-M) LoaderVersion 12.4(25e)JAY, RELEASE SOFTWARE (fc1)
Compiled Thu 03-Oct-13 03:35 by sdcunha
BL Build year: 13
Unable to locate IOS image with name **xx**.
Boot CMD: 'boot flash:/ap3g2-k9w8-mx.153-3.JD16/ap3g2-k9w8-xx.153-3.JD16'
Loading "flash:/ap3g2-k9w8-mx.153-3.JD16/ap3g2-k9w8-xx.153-3.JD16"...##################################################
File "flash:/ap3g2-k9w8-mx.153-3.JD16/ap3g2-k9w8-xx.153-3.JD16" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2600 Software (AP3G2-K9W8-M), Version 15.3(3)JD16, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Tue 05-Jun-18 02:41 by prod_rel_team
Initializing flashfs...
flashfs[2]: 61 files, 7 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 31739904
flashfs[2]: Bytes used: 15283712
flashfs[2]: Bytes available: 16456192
flashfs[2]: flashfs fsck took 9 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Copy in progress...CCCCCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0 present 8764 8000 0 A8000000 A8010000 0
timeout waitin for fw ready
nop failed
*Mar 1 00:00:14.823: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar 1 00:00:58.179: %SYS-5-RELOAD: Reload requested by Init. Reload Reason:
Radio FW image download failed ....
03-13-2019 11:43 PM
I had the same issue, I rest the AP
Step 1: Press the reset button, it's between POE IN and PWR port, just open the IP rated bolt.
Step 2: Then power up the AP, while holding the reset button
Step 3: Hold the reset button for like 20 secs, until the led status is steady Red.
then
ap: reset
that's it, AP will reload
03-14-2019 12:23 AM
02-20-2020 02:50 AM
Hi!
Any one have some new info regarding this issue? Fixed in 8.5.151?
BR, Pierre
02-29-2020 10:07 AM
I have exactly same problem. one from my six 3702i is booting in loop.
I found new version of software on Cisco support - Release 8.5.161.0 ED
but I don't have access to download, so I can't test
