CSCvb25644 - AP3700 Randomly entering into continous boot loop due to Radio Fw image download error
ABM Networking
Does anyone know the work around for this?
I can install any V7.x.x image and the AP works fine, install any 8.x.x image and the AP goes into the boot loop failing on the Radio FW Image download.
Tried updating the image via Rmon, is there a version I need to install to get this AP working with V8.2.151
33 Replies 33
Something is missing from this: What firmware is the AP running on or what firmware is the AP booting up to?
Secondary Bootloader - Starting system.
Montserrat Board
40MB format
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 92 files, 9 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 21112832
flashfs[0]: Bytes available: 20045824
flashfs[0]: flashfs fsck took 11 seconds.
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 0 seconds.
Base Ethernet MAC address: f4:cf:e2:90:32:d4
Boot CMD: 'boot  flash:/ap3g2-k9w8-mx.153-3.JF10/ap3g2-k9w8-xx.153-3.JF10;flash:/ap3g2-k9w8-mx.153-3.JF10/ap3g2-k9w8-xx.153-3.JF10'
Loading "flash:/ap3g2-k9w8-mx.153-3.JF10/ap3g2-k9w8-xx.153-3.JF10"...#################################################
File "flash:/ap3g2-k9w8-mx.153-3.JF10/ap3g2-k9w8-xx.153-3.JF10" uncompressed and installed, entry point: 0x1003000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, C3700 Software (AP3G2-K9W8-M), Version 15.3(3)JF10, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2019 by Cisco Systems, Inc.
Compiled Thu 13-Jun-19 18:51 by prod_rel_team
Montserrat Board
40MB format
Initializing flashfs...
flashfs[2]: 92 files, 9 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 21112832
flashfs[2]: Bytes available: 19787776
flashfs[2]: flashfs fsck took 12 seconds.
flashfs[2]: Initialization complete.
flashfs[4]: 0 files, 1 directories
flashfs[4]: 0 orphaned files, 0 orphaned directories
flashfs[4]: Total bytes: 11999232
flashfs[4]: Bytes used: 1024
flashfs[4]: Bytes available: 11998208
flashfs[4]: flashfs fsck took 0 seconds.
flashfs[4]: Initialization complete.
Copying radio files from flash: to ram:
Copy in progress...CCCCC
Copy in progress...CCCCCCCC
Uncompressing radio files...
...done Initializing flashfs.
Radio0  present 8764 8000 0 A8000000 A8010000 0
*Mar  1 00:00:17.207: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed (15)
*Mar  1 00:00:31.911: %DOT11-2-RADIO_FAILED: Interface Dot11Radio0, failed due to the reson code 44
-Traceback= 1294CC8z 1894814z 18950C8z 191DF98z 191E6E0z 192A5B0z 18A4290z 13ABB14z 13ABCF4z 13ABE60z 11A1FBCz 11A2234z 1425DB4z 140CB3Cz
*Mar  1 00:00:31.959: %SYS-5-RELOAD: Reload requested by Init. Reload Reason:
Radio FW image download failed ....
IOS Bootloader - Starting system.
flash is writable
flashfs[0]: flashfs fsck took 10 seconds.
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-k9w8-mx.153-3.JF10/ap3g2-k9w8-mx.153-3.JF10"...#########################
File "flash:/ap3g2-k9w8-mx.153-3.JF10/ap3g2-k9w8-mx.153-3.JF10" uncompressed and installed, entry point: 0x2003000
executing...
Montserrat Board
40MB format
executing...
What is strange. Everything is working fine untli power is ON. I can reboot device many times without any problem. But if I unplug cable from device. Device going in to loop. Reason code is same: 44.
Only what I can do, I put device to ROMMON mode delete one or two files form flash: and boot device manually by command
set BOOT flash:ap3g2-k9w8-mx.153-3.JF10/ap3g2-k9w8-mx.153-3.JF10
After reboot, AP checking firmware file on controled and downloading again. and after, device booting ok,
Everthing is working fine , no issue with connection and clinets until next power off.
What happens if you force the AP to boot the RCV file (from ROMMON)?
I didn't test this. Always delete some one file from firmware catalog. And boot again.
