CSCvd76906 - Management interface Gi0/0 randomly unreachable - 1
joe.doherty
Having the same issue as others above have mentioned. Hardware model: WS-C3650-24TD SW version:
03.06.07E
The int G0/0 will randomly stop responding to ICMP while this is happening the interface still shows UP/UP. We are able to access this switch through console cable shut no shut and the interface starts to respond again.
Same issue here, i'm on software release 16.3.5b
edit: if I wait long enough the issue is resolved on its own. A shut/no shut of the port or the port the management interface is connected to also helps though.
Jockizis
Same issue on a 3650 SW 03.07.04E.
