CSCve24102 - GUI should allow max 256 addresses per DHCP pool
mraz
Having the same issue of not being able to create DHCP pool of more then 256 address.
MaErre21325
hi,
did you find a solution?
via cisco bug search tool is not clear if it is limited to 256 ips or it can be extended in some ways....
