09-05-2018 10:15 AM
Do I need to install this fix on every node in a distributed deployment or does it auto-install to the other nodes in the cluster like the Patches do? How do I check if it's installed? the only way I know is command line: show logging application hotpatch.log
Solved! Go to Solution.
09-06-2018 01:37 PM
It's a hotpatch/hotfix that has to be installed by the CLI. Since you have to install it with the CLI, you have to go to every node in the deployment and execute the CLI command as you would a "normal" patch. Unfortunately no GUI option.
09-05-2018 03:31 PM
09-06-2018 05:15 AM
Thanks for the reply! Yeah I read the notes and installed on my admin node. But it did not say whether you had to install on all nodes or not.
Thank you!
09-06-2018 07:16 AM
09-06-2018 01:37 PM
