CSCvm14030 - Evaluation of positron for Struts remote code execution vulnerability August 2018
uspstech
Do I need to install this fix on every node in a distributed deployment or does it auto-install to the other nodes in the cluster like the Patches do? How do I check if it's installed? the only way I know is command line: show logging application hotpatch.log
It's a hotpatch/hotfix that has to be installed by the CLI. Since you have to install it with the CLI, you have to go to every node in the deployment and execute the CLI command as you would a "normal" patch. Unfortunately no GUI option.
Leo Laohoo
Yes, the patch needs to be installed in every node.
Read the Release Notes because it will provide very detailed steps on how to apply the fix.
Thanks for the reply! Yeah I read the notes and installed on my admin node. But it did not say whether you had to install on all nodes or not.
Thank you!
Push the firmware to the admin node and it will be re-distributed.
