CSCvm71860 - Cisco Identity Services Engine Reflected Cross-Site Scripting Vulnerability
AustinHarsh2908
There isn't a patch out for this yet right? ISE 2.4 Patch 8 I think is version 2.4(0.904) correct? I'm getting that from the bundle name: ise-patchbundle-2.4.0.357-Patch8-19041200.SPA.x86_64.tar.gz, but I don't know since it's kind of right in middle of it. Will a yet to be released patch 9 be version 2.4(0.906)?
Would be nice if the bug report listed patch numbers along with the version or if the patches more clearly reflected which version ISE will be if installed.
user101111
Did you ever get an answer to this? I'm wondering the same thing.
This bug was noted as resolved in the Release notes in Ise 2.4(0.357) Patch 6, so patch after that will also include this fix. Such as Patch 7-9
ISE 2.4(0.357) Release Notes
Resolved Caveats in Cisco ISE Release 2.4.0.357- Cumulative Patch 6
The following table lists the resolved caveats in Release 2.4 cumulative patch 6.
Patch 6 might not work with older versions of SPW. MAC users must upgrade their SPW to MACOSXSPWizard 2.2.1.43 or later, and Windows users must upgrade their SPW to WinSPWizard 2.2.0.53 or later.
Caveat ID NumberDescription
CSCux55288
Guest remember-me breaks ISE Guest Activity Logging
CSCuy41309
ISE 2.x Unable to delete endpoint from endpoint group
CSCuz00603
Unable to add duplicated mappings to multiple SXP VPNs
CSCvb17967
ISE fails to read response from MDM with special characters
CSCvb45390
Collection Filters configured with User name is not working for TACACS Author/Acct
CSCvc06629
[ISE] SMS notifications in non-English containing <BR> HTML tag
CSCvd79952
EasyConnect CoA not sent after session merge in distributed deployment
CSCvf03310
ISE email notifications to guests sends twice email for approval and guest user
CSCvf19364
ISE 2.2 no patch, SXP process fails when trying to create network subnet static mapping
CSCvf30591
ISE 2.2: Disabled password Lifetime, however getting reminder for account expiration.
CSCvf75225
ISE 2.1-P3 || high CPU seen in PAN due to 100K limit in redis
CSCvg86743
Cisco Identity Services Engine Stored Cross-Site Scripting Vulnerability
CSCvh09779
ISE 2.x TACACS log extremely slow
CSCvh11308
Cisco Identity Services Engine Logs Cross-Site Scripting Vulnerability
CSCvh19430
ISE 2.x : Guest account activation time discrepancy for imported accounts
CSCvh31565
ISE fails to re-establish TCP syslog connection after break in connectivity
CSCvh54905
Identity Admin cannot see users under Identities tab
CSCvh83222
ISE: Need a report/dashboard for total unique endpoints
CSCvh91118
Flexibility needed to choose the time intervals in disclosing the user name for failed auth
CSCvh97544
Short CPU spikes can be observed when client didnt respond and ISE is used as RADIUS Proxy
CSCvi21043
Library conds referrred in policies are getting deleted; evaluation is giving deny access
CSCvi23542
Unexpectedly error during stress authentications : RPC Logon request failed - STATUS_ACCESS_DENIED
CSCvi30462
Bulk guest import does not work using when logged into sponsor portal using SAML provider,
CSCvi37480
SNMPv3 COA failures on ISE using HP switches
CSCvi41678
Endpoint Attributes not updated in context visibility
CSCvi42404
validDays does not match span of fromDate to toDate for ERS created guests
CSCvi43687
ISE 2.2 Endpoint export may contain duplicate entries
CSCvi48298
Policy Hit count value gets nullified while click on REFRESH button.
CSCvi50320
EST Service not running owhen ISE iseca folder missing
CSCvi61204
ISE 2.1 Endpoint Purge policy is matched but job halts during execution.
CSCvi67780
ISE Internal CA : SAN ext validation fails if it isn't the first entry in RequestedExtensions in CSR
CSCvi68271
ERS API get all endpoints not returning description field as stated in documentation
CSCvi97332
Unsupported character Backslash has to be added to the UI error message while creation of admin user
CSCvi99561
AC 4.6 Application enforcement is not working for Torrent
CSCvj01047
Password length limitation when adding DC's in the PassiveID section of 32 characters.
CSCvj05563
Cannot delete security groups having virtual network mapping
CSCvj24095
Unknown Radius Flow is set to RadiusFlowType when updating ExternalIdStoreDictionary
CSCvj25696
User customer attributes order doesn't change after drag drop and save.
CSCvj31243
ISE 2.3 AD Group SID Update fails for Groups referenced in the policies
CSCvj50257
Active endpoints are mismatched from expected value
CSCvj57593
SNMP CoA is not sending correct SNMP traps
CSCvj62592
Cisco Identity Services Engine (ISE) Java Deserialization Vulnerability
CSCvj62599
Cisco Identity Service Engine (ISE) unsafe deserialization in Adobe Action Message Format (AMF)
CSCvj62614
Cisco Identity Services Engine (ISE) File Upload Code Execution Vulnerability
CSCvj63376
ISE 2.2 VPN MDM- Compliance not updated from MDM Compliance Checker for active session
CSCvj64763
DNAC-ISE:Pxgrid failover fails with 2.4 patch1 with DNAC - ISE Integration
CSCvj65552
ISE 2.4 Backup Input Validation does not occur on backup name characters
CSCvj67414
ISE HSTS Max-Age parameter is too agressive no includedDomains flag
CSCvj72699
ISE stops publishing SXP mapping
CSCvj73152
Enable VLAN DHCP release breaks guest flow for ISE 2.4
CSCvj77878
pxgrid: XMPP Cleartext Authentication
CSCvj92976
ISE : Incomplete error message while importing an icon under Network Device Profiles
CSCvj95709
Enable pxGrid in FIPS mode
CSCvj99698
Guest password is not reset if Sponsor does not have rights to view the Guest Password
CSCvk01682
ISE allows importing multiple instances of same language in portal setup
CSCvk04424
Changed name for My Reports against Policy Set match removes the delete option from My Reports
CSCvk10156
RBAC SuperAdmin Data Access over written by read-only data access for Network Device Groups
CSCvk13724
EPG mappings not created on ISE
CSCvk23161
ISE stops responding to TACACS requests.
CSCvk23532
Remove GMT portion from $ui_start_date_time$ and $ui_end_date_time$ on Email Notifications
CSCvk27295
NMAP fails to execute when an EP matches a Admin Created profiling policy
CSCvk28847
ISE sponsor's e-mail shoud not be in CC when view/print guests' passwords is disabled
CSCvk34232
Posture remediation files are limited to 50MB
CSCvk38374
ISE 2.4 Sponsor-Group OWN_ACCOUNTS email association
CSCvk39421
ISE offline profiler feed service unavailable 17/07/18
CSCvk40105
Editing guest user throws pop up error when creating with java scripts in first and last name
CSCvk48315
Live sessions are not seen in ISE Live logs page in ISE 2.4
CSCvk51906
DST changes are not honored by the shift job which is causing the data movement issues on MNT nodes
CSCvk55285
ISE doesn't validate the data type date in the custom endpoint attribute
CSCvk58134
SAML authentication is showing wrong Identity store in Sponsor Login and Audit report
CSCvk59357
Admin warned of license non-compliance even after adding new licenses
CSCvk65898
ISE 2.4 : Social Login e2e flow fails due to recent changes done on Facebook side
CSCvk68196
SNMPv3 profiling works only with DES or AES128 privacy protocol
CSCvk70087
SecureSyslogCollectors should be disabled by default on remote log targets.
CSCvk71816
ISE ADE-OS - when trying to change timezone there should be a warning stated it is not supported
CSCvk72606
ISE- Can login to GUI with disabled admin accounts.
CSCvk74190
Radius Token Identity Caching Timeout not Configurable
CSCvm00127
ISE sponsor email customization doesn't add image properly
CSCvm03842
PxGrid SSL / TLS Renegotiation Handshakes MiTM Plaintext Data Injection - CVE-2009-3555
CSCvm09377
HTTP Request Header for ISE fails if it contains @ in email
CSCvm09493
ISE 2.4 | Unable to save multiple custom attributes at once
CSCvm11230
Customer sees no data available for this record for "Details" page in Live Logs
CSCvm12105
ISE 2.3 not hitting policy with Session BYOD-Apple-MiniBrowser-Flow condition
CSCvm12281
ISE 2.3 Context Visibility Authentication Policy column is blank.
CSCvm12443
ISE should not send alarm for 'ERS-Media-Type' not present in ERS header
CSCvm14030
Evaluation of positron for Struts remote code execution vulnerability August 2018
CSCvm15059
ISE 2.1+ : Identity Source Sequence info button information is wrong for Sponsor Portal
CSCvm16060
Cannot Disable Telnet Change Password
CSCvm16523
ISE 2.3 to 2.4 upgrade is failing with error "nodes are not on the same ISE patch version"
CSCvm16952
Oracle Security Alert Advisory - CVE-2018-3110
CSCvm20561
ISE 2.x || Cisco-Device profiler policy missing the tandberg OUI as a condition
CSCvm21147
ISE: After upgrading to ISE 2.4 schedule backup are not working.
CSCvm22262
AMQP Cleartext Authentication Vulnerability
CSCvm26334
Endpoints not re-profiled after config restore and import new profiles
CSCvm27249
PassiveID Probe hprof files in temp folder
CSCvm29583
ISE AD lookup broken due to non-whitelisted domain lookup failing
CSCvm31919
IE11 : Trash icon linked to MAC address search box in Context Visibility
CSCvm32107
Unable to delete Root Network Device Group
CSCvm32303
Rest API- Unable to retrieve Guest User Details using ToDate filters
CSCvm33217
AD groups with more than one space doesn't allow authZ policy to be saved
CSCvm33673
Difference between Oracle and ES in terms of description
CSCvm34694
Newly created Network Device Model Name and Software Version are not present in GUI
CSCvm39902
Maintain Connectivity During Reauthentication option not working
CSCvm39909
Live log detailed reports shows msec instead of seconds for session timeout
CSCvm41485
ISE 2.3 : Unable to access NFS repository and scheduled reports not working using NFS respository
CSCvm41759
'Error 400' after pressing Sing Out on the Manage Guest Accounts page.
CSCvm45072
OWASP ZAP reports Cross Site Scripting (DOM Based) on pxGrid Web application
CSCvm45330
pxGrid cert change causing onAuthzRequest DENIED
CSCvm45941
ISE 2.4 not sending "Framed-IP-Address" attribute in profile when using leading zero
CSCvm47317
30+ GB files left behind after successful ISE 2.4 upgrade
CSCvm47507
Changes made in allowed protocols is missing in change configuration audit reports
CSCvm47638
ISE-secondary node doesnt send COA when guest account gets suspended or deleted
CSCvm48075
Manual CoA fails from Context Visibility if user never accesses Live logs or Live Sessions prior
CSCvm49084
ISE PB portal files are not restored with a restore of an old backup
CSCvm49503
WasMachineAuthenticated EQUALS False No Longer Parsed in Runtime--ISE 2.4
CSCvm57650
BYOD TLS not working for IOS 12 FCS release
CSCvm61134
SXP debug logs are not dumped in sxp.log unless services are restarted
CSCvm62783
'EST-CSR-Request' dictionary condition does not work
CSCvm62862
Cisco Identity Services Engine Logging Cross-Site Scripting Vulnerability
CSCvm66696
ISE 2.4 Conditional CoA failure upon EndPoint Identity Group change
CSCvm66751
Guest AUP: AUP acceptance is triggering replication event
CSCvm67561
Accounting messages from ASR1K not saved and not shown in ISE Reports
CSCvm69965
Chrome:Cannot create new ByoD portal
CSCvm70470
Max Sessions" value can not be applied on GUI after applying 2.2p10 or 2.3p4
CSCvm71860
We are running on 2.4 Patch 8 and 10, and still having the slow TACACS response from a PSN. Any known solution yet?
