CSCvn05797 - Cisco Firepower Management Center Cross-Site Scripting Vulnerability
yeekhiang.ching
When is the fix for this bug will be release? Or, is there any workaround for this vulnerability?
5 Replies 5
balaji.bandi
Not able to view the bug, is this FMC 6.3 ?
BB
Yes, it's FMC 6.3 currently and this bug is affecting this FMC version. I would like to know if there's a fix coming soon?
FMC 6.3.X is quite new, suggest to raise an TAC case to investigate quicker and give you alternative solution involving developers.
BB
Thanks, BB. Will raise a TAC case for solution :)
This vulnerability has bug fixed releases. Please refer to the updated link:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn05797/?rfs=iqvred
thank you.
