CSCvo09511 - CLI hangs for several minutes when applying certain interface-level commands
We experienced this exact issue on a C9348GC-FXP with the following configuration:
# show module
Mod Ports Module-Type Model Status
1 54 48x100/1G + 4x10G/25G + 2x40G/100G Et N9K-C9348GC-FXP active *
After applying the "channel-group 10 mode active" command to a range of 4 ports, the CLI hangs for several minutes. Seemingly longer than 3-4 minutes even, but I did not time this.
The issue can be reproduced every time.
This switch is running nxos 9.2.3
0 Replies 0
