CSCvq47743 - AnyConnect and Management Sessions fail to connect after several weeks - FPR2130 ASA Mode
Agung1007
Did anybody have issue like this?
After >7 Days from last reload, the ASA unable to Anyconnect VPN, SSH, ASDM.
If we want to access the ASA we need to SSH to Chassis and then "connect asa"
I have customer that using FPR 2130 with ASA Mode (Multiple Context),
The issue start on Mid October,
Previously we are using ASA ver 9.12.3.9, then we upgrade to 9.12.3.12 on End of October, but still cant solve the issue.
Lastly, at 19 Dec we try to upgrade the ASA to 9.12.4.10 (which in this link 9.12.4.10 Interim Release Notes this case is solved)
but,
As for today the issue still happen/not solved.
abinodattil
we had somethign similar, where Ssh stops working and we cannt get in
we have to use oob
but a reload temp fix it,
