CSCvq65075 -PoE issue inline power denied.Reason: insufficient power
v_infinity
Seeing a similar issue on 9300: (Is this related to same bug CSCvq65075 ?)
Model: C9300L-24UXG-4X
Version: 17.03.05
SW Image: CAT9K_IOSXE
802.3bt mode enabled on switch:
cisco9300(config)#hw-module switch 1 upoe-plus
!!!WARNING!!!This Configuration will powercycle the switch to make it effective.Would you like to continue y/n?[confirm]
Building configuration...
[OK]
cisco9300(config)#
cisco9300#show switch detail
Switch/Stack Mac Address : dc0b.0965.7480 - Local Mac Address
Mac persistency wait time: Indefinite
H/W Current
Switch# Role Mac Address Priority Version State
*1 Active dc0b.0965.7480 1 V02 Ready
Stack Port Status Neighbors
Switch# Port 1 Port 2 Port 1 Port 2
1 DOWN DOWN None None
cisco9300#
Port Config:
interface GigabitEthernet1/0/4
switchport trunk native vlan 3002
switchport mode trunk
power inline static max 30000
end
--> 802.3bt capable AP is connected to above port
Observations:
1. Port status is seen down and AP is not powered
cisco9300#sh ip int brief gi1/0/4
Interface              IP-Address      OK? Method Status                Protocol
GigabitEthernet1/0/4   unassigned      YES unset  down                  down
cisco9300#
Switch Logs seen:
*Jul 6 13:20:00.067: %ILPOWER-5-IEEE_DISCONNECT: Interface Gi1/0/4: PD removed
*Jul 6 13:20:09.058: %ILPOWER-5-DETECT: Interface Gi1/0/4: Power Device detected: IEEE PD
*Jul 6 13:20:09.059: %ILPOWER-5-ILPOWER_POWER_DENY: Interface Gi1/0/4: inline power denied. Reason: insufficient power
Switch Logs in debug mode:
*Jul  6 14:02:24.339: ILP:: ilp enabled in hwidb Gi1/0/4
*Jul  6 14:02:24.339: ILP:: ILP CLI 'no shut' handling ( Gi1/0/4 ) Okay
*Jul  6 14:02:24.339: ILP:: Sending poe coredump msg to slot:1
*Jul  6 14:02:24.340: ILP::
Sending E_ILP_GET_DEBUG_CORE_DUMP IPC message from RP to platform
*Jul  6 14:02:24.340: ILP:: ilp hwidb Gi1/0/4 admstate 3
*Jul  6 14:02:24.340: ILP:: ilp hwidb Gi1/0/4 admstate static 3
*Jul  6 14:02:24.341: ILP:: ILP CLI 'no shut' handling ( Gi1/0/4 ) Okay
*Jul  6 14:02:24.342: ILP:: ilp enabled in hwidb Gi1/0/4
*Jul  6 14:02:24.343: ILP:: Gi1/0/4: State=NGWC_ILP_SHUT_OFF_S-0, Event=NGWC_ILP_CLI_START_DETECT_EV-17
*Jul  6 14:02:24.343: ILP:: START_DETECT_EV, shutoff_state Gi1/0/4
*Jul  6 14:02:24.343: ILP:: Sending poe detect msg to slot:1 port:4
*Jul  6 14:02:24.344: ILP::
Sending E_ILP_START_IEEE IPC message from RP to platform
*Jul  6 14:02:24.345: ILP:: Rx Response ILP msg: response_code 27, sw_num 1
*Jul  6 14:02:24.345: ILP:: ILP msg: received E_ILP_GET_DEBUG_CORE_DUMP
*Jul  6 14:02:24.345: ILP:: Inline power process coredump for switch 1
*Jul  6 14:02:24.352: ILP:: ilpsm posting link down event Gi1/0/4
*Jul  6 14:02:24.356: ILP:: ilpsm posting link down event Gi1/0/4
*Jul  6 14:02:24.363: ILP:: ilpsm posting link down event Gi1/0/4
*Jul  6 14:02:26.338: %LINK-3-UPDOWN: Interface GigabitEthernet1/0/4, changed state to down
*Jul  6 14:02:28.363: ILP:: Gi1/0/4: State=NGWC_ILP_DETECTING_S-2, Event=NGWC_ILP_WAIT_LINK_DOWN_TIMER_EV-42
*Jul  6 14:02:28.363: ILP:: Sending poe detect msg to slot:1 port:4
*Jul  6 14:02:28.363: ILP:: timer event, Null swidb .
*Jul  6 14:02:28.484: ILP::
Sending E_ILP_SET_ICUTOFF IPC message from RP to platform
*Jul  6 14:02:28.484: ILP:: Sending icutoff current msg to slot:1 port:21
Note: AP is powered (via BT power) successfully when power limit is removed on switch port
5 Replies 5
v_infinity
When issue occurred, sufficient power budget was available on switch
cisco9300#show power inline
Module Available Used Remaining
(Watts) (Watts) (Watts)
1 880.0 296.5 583.5
Post the complete output to the command "sh power inline Gi1/0/4 detail".
v_infinity
cisco9300(config)#int gi1/0/4
cisco9300(config-if)#shutdown
cisco9300(config-if)#no shutdown
cisco9300(config-if)#end
--> Wait for around 1 minute after running above command `no shutdown` on the port gi1/0/4
cisco9300#show power inline gi1/0/4
Interface Admin Oper Power Device Class Max
(Watts)
Gi1/0/4 static off 30.0 n/a n/a 30.0
cisco9300#show power inline gi1/0/4 detail
Interface: Gi1/0/4
Inline Power Mode: static
Operational status: off
Device Detected: no
Device Type: n/a
IEEE Class: n/a
Discovery mechanism used/configured: Ieee and Cisco
Police: off
Power Allocated
Admin Value: 30.0
Power drawn from the source: 30.0
Power available to the device: 30.0
Actual consumption
Measured at the port: 0.0
Maximum Power drawn by the device since powered on: 0.0
Absent Counter: 0
Over Current Counter: 0
Short Current Counter: 0
Invalid Signature Counter: 0
Power Denied Counter: 0
Power Negotiation Used: None
LLDP Power Negotiation --Sent to PD-- --Rcvd from PD--
Power Type: - -
Power Source: - -
Power Priority: - -
Requested Power(W): - -
Allocated Power(W): - -
Four-Pair PoE Supported: Yes
Spare Pair Power Enabled: No
Four-Pair PD Architecture: N/A
cisco9300#
cisco9300#
Device Detected: no
Device Type: n/a
Power Allocated
Admin Value: 30.0
Someone has manually configured the port for only 30.0wac.
That is the actual problem.
No power is received on port when static power limit is set.
The AP is capable of operating on 30w power too.
As soon as power limit is removed from port, everything works fine
