CSCvt02962 - Uplink Port-channel Trunk member link Port LED truns to amber blinking after link down/up
dbooth
We have a 9300 running 16.12.4 (listed in the bug as a fixed release) with a standard port (not on an uplink module) where a redundant port-channel member link has it's port status LED lit amber, and nothing in the actual port status or logging under CLI suggests any sort of error. Would appreciate if anyone else can corroborate similar behaviour? Thanks.
8 Replies 8
balaji.bandi
Can you post the configuration of that ports ?
BB
dbooth
Ten ports in the etherchannel, all configured identically and pretty basic. The active ports appear to be working fine.
interface Port-channel11
switchport mode trunk
interface GigabitEthernet1/0/1
channel-group 11 mode active
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet2/0/1
interface GigabitEthernet2/0/2
interface GigabitEthernet2/0/3
interface GigabitEthernet2/0/4
interface GigabitEthernet2/0/5
dbooth
Example corresponding ports from other side of port-channel, e.g. ports on both sides are all set to 'active';
interface GigabitEthernet5/0/47
channel-group 1 mode active
interface GigabitEthernet5/0/48
balaji.bandi
Can you post below output from both the devices :
show etherchan 1 summary
show log - both switches
BB
dbooth
etherchannel summary on both switches showed 8 active ports as (P) participating and 2 ports as (H) as expected, including the one with the amber LED.
'sh log | i 2/0/5' where Gi2/0/5 is the port showing the amber LED just showed port up and port down events. Sorry I don't have the output but this is recollection from initial troubleshooting.
i would still insists to see the output below : (before we think of anything)
BB
#show etherchannel 11 summary
Flags:  D - down        P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
R - Layer3      S - Layer2
U - in use      f - failed to allocate aggregator
M - not in use, minimum links not met
u - unsuitable for bundling
w - waiting to be aggregated
d - default port
A - formed by Auto LAG
Number of channel-groups in use: 11
Number of aggregators:           11
Group  Port-channel  Protocol    Ports
11     Po11(SU)        LACP        Gi1/0/1(P)      Gi1/0/2(P)
Gi1/0/3(P)      Gi1/0/4(P)
Gi1/0/5(P)      Gi2/0/1(P)
Gi2/0/2(P)      Gi2/0/3(P)
Gi2/0/4(H)      Gi2/0/5(H)
#show etherchannel 1 summary
d - default port
1      Po1(SU)         LACP        Gi1/0/47(P)     Gi1/0/48(P)
Gi2/0/47(P)     Gi2/0/48(P)
Gi3/0/47(P)     Gi3/0/48(P)
Gi4/0/47(P)     Gi4/0/48(H)
Gi5/0/47(P)     Gi5/0/48(H)
Looks good, when you get chance or maintenance window time, shut  and no shut the Port-channel.
are you seen any Operational impact for now ?
BB
