CSCvu10721 - SSH connection getting rejected FIPS mode enable
bahoug
I hit this bug on 10.2.5. https://bst.cisco.com/bugsearch/bug/CSCvu10721
If the fix/workaround is to delete the RSA key and only have the ecdsa 521 key I should be able to enable fips mode without the RSA key right? I would fully expect to be able to enable fips mode with just he ecdsa 521 key.
TOR# show ssh key
could not retrieve rsa key information
could not retrieve dsa key information
ecdsa Keys generated:Tue Apr 11 17:53:13 2023
ecdsa-sha2-nistp521 AAAAE2VjZHNhLXNoYTItbmlzdHA1MjEAAAAIbmlzdHA1MjEAAACFBAF1Lubb+4v6TupuNfA6dUpvSNxYGfzgWi8Fyjua9OtFQCaTPKQ7+P8bn4yhKlGTvTrwufDnm/+0WWcmqL30ET3AzQCkfLKPFJCTYpJIYrPFmyFEgsbacYJgrXVTo1TIbeLFm6a0msl+zWiSrtViB4O4i8WNiblf1
OCx5ef44uAaXUmogA==
TOR(config)# fips mode enable
As per NIST requirements, the minimum RSA Key Size has to be 2048 in FIPS Mode
Generate RSA key with 2048 bits
balaji.bandi
could not retrieve rsa key information   <<< you do not have RSA Keys.
Connect to the console  and follow below steps :
N9k-Switch# conf t
N9k-Switch(config)# no feature ssh
N9k-Switch(config)# no ssh key rsa
N9k-Switch(config)# ssh key rsa 2048
N9k-Switch(config)# feature ssh
New SSH Key has a bitcount of 2048:
N9k-Switch(config)# show ssh key (check RSA keys)
N9k-Switch(config)# fips mode enable (this required reload the switch)
BB
