CSCwd67224 AIX CSW agent not able to connect due to fragmentation
aboch
IBM released 5.3.0.9 ipfilter does not completely fix the issue.
Please refer to https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwj92795
The problem is not specific to CSW Agent <-> CSW Cluster communications.
It may affect any IP fragmented traffic to the workload which matches a rule in ipfilter.
alissonhines9
You are write it is not specific to CWW Agent.
antoinejack29
The CSCwd67224 AIX CSW agent connection issue likely arises  from network fragmentation. Check MTU settings and adjust packet size limits.
