Facing difficult-to-clarify problems on the Nexus3548
allenblack0308
HiHi~ facing some difficult to clarify problems in NX3548(NXOS 9.2(3))here are some information:
2019 Jul 15 13:52:42 Nx3548 %$ VDC-1 %$ %SYSLOG-2-SYSTEM_MSG: Attempt to configure logging server with: hostname/IP 10.88.60.126,severity 5,port 514, - syslogd
2019 Jul 15 13:53:35 Nx3548 %$ VDC-1 %$ %SYSLOG-2-SYSTEM_MSG: Logging server configuration: hostname/IP 10.88.60.126,severity 5,port 514, - syslogd
2024 Apr 13 15:16:55 Nx3548 %$ VDC-1 %$ %SYSMGR-2-SERVICE_CRASHED: Service "callhome server" (PID XXXXX) hasn't caught signal 9 (no core).
2024 Apr 13 15:16:55 Nx3548 %$ VDC-1 %$ %SYSMGR-SLOT1-2-SERVICE_CRASHED: Service "aclqos" (PID XXXXX) hasn't caught signal 6 (core will be saved).
2024 Apr 13 15:16:55 Nx3548 %$ VDC-1 %$ %SYSMGR-SLOT1-2-HAP_FAILURE_SUP_RESET: Service "aclqos" in vdc 1 has had a hap failure
2024 Apr 13 15:16:55 Nx3548 %$ VDC-1 %$ %SYSMGR-2-SERVICE_CRASHED: Service "Platform Manager" (PID XXXXX) hasn't caught signal 9 (no core).
2024 Apr 13 15:16:55 Nx3548 %$ VDC-1 %$ %SYSMGR-2-SERVICE_CRASHED: Service "netstack" (PID XXXXX) hasn't caught signal 9 (no core).
exception information --- exception instance 1 ----
Module Slot Number: 0
Device Id : 134
Device Name : System Manager
Device Errorcode : 0x0000016e
Device ID : 00 (0x00)
Device Instance : 00 (0x00)
Dev Type (HW/SW) : 01 (0x01)
ErrNum (devInfo) : 110 (0x6e)
System Errorcode : 0x401e008a Service on linecard had a hap-reset
Error Type : FATAL error
PhyPortLayer : 0x0
Port(s) Affected : none
Error Description : aclqos hap reset
DSAP : 0 (0x0)
UUID : 1 (0x1)
Time : Sat Apr 13 15:17:11 2024
(Ticks: 661A3177 jiffies)
Sat Apr 13 15:20:26 2024: Card Uptime Record
Uptime: 114, 0 days 0 hour(s) 1 minute(s) 54 second(s)
Reset Reason: Reset Requested due to Fatal Module Error
Card Mode Runtime
Have searched for some possible BUGs:
https://bst.cisco.com/bugsearch/bug/CSCvt35218?rfs=qvred
https://bst.cisco.com/bugsearch/bug/CSCwi24874?rfs=qvred
Any suggestions other than upgrading the OS version? thanks
Mark Elsen
         >...Any suggestions other than upgrading the OS version? thanks
  - Well sorry , but for these issues consider that kind of mandatory and or use latest advisory software version ; they are 'simply bugs'  and nothing else will help besides upgrading and evaluating afterwards ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
 M.
       Beauty and terror
      Just keep going
       No feeling is final
