OS admin login works with Subscriber. Does not work with Publisher. This issue is for only one account. Other accounts are working fine
laxmanraje31
OS admin login works with Subscriber. Does not work with Publisher. This issue is for only one account. other cli accounts are working fine
>From RTMT check audit logs to see why the account isn't able to login
System>Tools>Trace>Trace and Logs Central > Audit Logs (last one)
Hi there
Seems to be you are hitting this bug if you are using 11.5(0.99838.5). Upgrade to one of the fixed versions.
OS admin login works with Subscriber. Does not work with Publisher - CSCuz84221
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCuz84221/?rfs=iqvred
Hope this Helps
Cheers
Rath!
***Please rate helpful posts***
