%PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7, ISR4431
Hello everyone,
I think that I am experimenting the bug CSCvj62552, but i dont find a workaround for this. The logs on the router 4431 show this continuouisly:
Nov 13 14:03:19.508: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033572263951385942 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 13 16:28:51.799: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:002 TS:00033580996825626160 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 14 04:28:00.109: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033624142711663023 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 14 07:53:24.942: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033636466851940428 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 14 08:26:14.854: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033638433431841930 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 14 08:59:38.701: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:002 TS:00033640440387322253 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 14 11:44:14.654: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:002 TS:00033650312564640208 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 14 13:35:07.189: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033656965799844700 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 14 17:10:13.157: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033669871042521527 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 14 17:42:36.982: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:002 TS:00033671816905823625 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 15 00:37:02.714: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:002 TS:00033696678019239470 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 15 07:52:51.399: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033722826309560705 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 15 07:53:39.406: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033722873239881844 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 15 09:13:02.472: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033727637112577322 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
Nov 15 09:19:25.839: %IOSXE-5-PLATFORM:cpp_cp: QFP:0.0 Thread:001 TS:00033728021532001226 %PUNT_INJECT-5-DROP_PUNT_CAUSE: punt cause policer drop packet casue 7
I don´t configured  a punt policies on the router, the punt policies are the default. Someone has experimentig this problem too?
balaji.bandi
yes you are correct there is no workaround for that (if you using the version mentioned in the bug)
but there is another thread user able to resolve the issue :
follow the thread and see if that helps (if not contact TAC raising a ticket, if that affecting any live services)
https://community.cisco.com/t5/routing/high-cpu-utilization-on-isr4431-k9-freezing/td-p/3856682
BB
Thanks Balaji,
I searched if with a upgrade of the firmware to 16.06.07 (Cisco Recomended version) this bug was resolve, but i dont found documentation about this. Do you know if with a upgrade this problem resolve?
if you are able to upgrade to a new version as recommended with no service effecting, my suggestion to upgrading.
if this impacting your environment, and kit in smartnet, contact TAC for second suggestion.
BB
